FXR problem
Old Mar 21, 2009 | 10:19 PM
jblank37's Avatar
jblank37
Default FXR problem
I don't know for sure what section of the forum to ask this, but being as how I stay here most of the time, I thought I would ask here. I have a friend who has a 92 FXR. The problem is, it runs great for maybe 40 or 50 miles. Then it will shut down. He will wait for maybe 5 or 10 minutes, starts back up and runs good. The bike has a new battery. He has checked and rechecked battery connections. He has also replaced the voltage regulator and I believe changed a couple of relays. Anyone have any ideas as to what may be going on? Any help would be very much appreciated. Thanks.
Old Mar 21, 2009 | 10:27 PM
bberck's Avatar
bberck
Check the fuel lines for bad spots.
I had a work truck one time that did the same thing. It would run for awhile but then the fuel line would collapse cutting off the fuel. After it sat a few minutes the line would uncollapse (word?) and the truck would run fine for awhile before it did it again.
Just 1 idea for ya.
Old Mar 21, 2009 | 10:34 PM
jblank37's Avatar
jblank37
bberck, thanks for the reply. I should have mentioned that I believe that it has to be an electrical problem since it will not try to start for those 5 or 10 minutes. Nothing when you hit the start button.
Old Mar 21, 2009 | 11:41 PM
JaronB's Avatar
JaronB
Maybe pull the fuses and check for corrosion and put some dielectric tune up grease on it. Tighten all of the connections! Even our newer bikes have this fuse corrosion problem if you water down your bike. Check for wire rubs!! Also use the troubleshooting guide in the shop manual. My dad has a 90 FXR and he had a similar problem. He thought it was the voltage regulator, but when he took it off the wire were bare with all the rubber rubbed off.
Old Mar 22, 2009 | 12:58 AM
Doughboy's Avatar
Doughboy
sounds like a dead short.start tracing wires.when i first read i was thinking a coil was going or gone bad,until i relized you said it wouldnt do anything for 5 or 10 min's.i would bet its taking awhile for the relays to reset.just my 2 cents
BAR55
Sep 28, 2013 09:24 AM
Rampart1664
Sep 10, 2011 03:04 PM
Tmekanik
Aug 29, 2009 10:03 PM
ccardiff
EVO
May 26, 2009 12:27 PM
harleydad98
Jul 31, 2008 01:15 PM
