Engine Starting after PCV Install
Old Mar 22, 2009 | 08:12 AM
Costnsg's Avatar
Costnsg
Default Engine Starting after PCV Install
After installing a stage 1 upgrade including a PCV, I noticed my engine would turn over more times before starting than before the PCV. I discussed this with Keith at Fuelmoto and he advised that I not wait for the fuel pump to stop its "hum" before hitting the start button. I can't recount the explanation he gave me, but it works. If you hit the start button right away after turning on the switch, there is no delay (extra cranking). I had been in the habit of waiting for the fuel pump noise to subside before hitting the start button.
I don't recall seeing this in any of the literature, so I thought I'd pass it on to those who might experience what I did. Probably old news to some of you.
Old Mar 22, 2009 | 08:22 AM
davidc's Avatar
davidc
Before I installed my PC-V I used to wait, now I do the same thing turn it on and hit it, starts on the 2nd or 3rd rev.
Old Mar 22, 2009 | 08:31 AM
YellowHawk's Avatar
YellowHawk
I noticed the same thing after installing my PCIII. I'll give this a try. Thanks for the tip.
Old Mar 22, 2009 | 11:40 AM
bberck's Avatar
bberck
The issue is the PC powers back off if you wait to start it so thats why it cranks more. At least thats what I have been told.
Old Mar 22, 2009 | 04:09 PM
Jay837's Avatar
Jay837
2nd Gear
The Power Commander is powered off of the front injector. That is why you shouldn't wait for the fuel pump to cut off. I also crank mine with the light on.
Old Mar 22, 2009 | 05:16 PM
catalac's Avatar
catalac
Mine does the same thanks for the info on starting while charging the fuel system, I'll try it.
Old Mar 22, 2009 | 05:32 PM
PigInaBlanket's Avatar
PigInaBlanket
Yep, I've been doing this since I put my PC III on and read about that trick on this forum about a year ago.
And if anyone tells you that you should be waiting till the little engine light goes out before trying to start it, just laugh at them and walk away.
Old Mar 23, 2009 | 03:20 PM
cardboard's Avatar
cardboard
My PCV does it and I've had it dyno tuned. When it warms up it won't do it as bad. But I still do not like it.
Old Mar 23, 2009 | 03:24 PM
EDZ82FXR's Avatar
EDZ82FXR
I just got done installing my pc5 on my street bob, I listened to the guys and didnt wait for the fuel pump to kick off, i heard the fuel pump hit the start button 1 turn of it and the bike starts right up no problems at all..Seems to work very well for me, and it is 30some degrees and the bike started right up
Old May 13, 2009 | 01:46 PM
magnethead's Avatar
magnethead
Yup, just put on a PCV on my Iron, I had the habit of waiting too and was annoyed with the extra cranking. Rang Dynojet, and they explained the starting system was the same as in some car (Ford I think) and I that case there is no waiting when the key turns. They said there is absolutely no problem hitting start the minute the engine primes.
I just hit the starter the minute the jets kick in happy days
clyles
Sep 8, 2015 02:14 PM
HDPursuit
Nov 22, 2011 11:17 AM
GPHDXLC
Jul 3, 2011 07:41 PM
streeteagle
May 24, 2010 12:11 AM
SE120RG
Jul 31, 2009 04:28 PM
