Help!! Pcv problems
Old Mar 22, 2009 | 09:42 PM
HuskerPower's Avatar
HuskerPower
Exclamation Help!! Pcv problems
ok so I finally got a chance to put my PCV on, after getting everything hooked up just like the directions said, when I tried to start my bike I wouldn't start, It isnt getting any spark? anyone else have this problem or any advice?
Old Mar 22, 2009 | 10:13 PM
moguy's Avatar
moguy
triple check all connections.
Old Mar 22, 2009 | 10:39 PM
LilBudyWizer's Avatar
LilBudyWizer
My guess would be the cable isn't seated properly. You could check continuity through the patch cable from the power commander to ecm, but both the front and rear coil lines been bad seems less likely than the cable just not being seated properly. You could use the software to check the connection to the power commander and use it to read data off the ecm to check the connection from it to the ecm.
You should hear the fuel pump run when you first turn on the bike though you have to leave it off a minimum amount of time for it to repressurize. You should also hear the IAC run when you turn it off. I assume the power commander can read dtc codes so check for those. The IAT and MAP should read ambient temp and pressure. The battery should show 14.1 or so though it may have dropped due to cranking. Cranking you should get 300 rpms or so.
If everything seems fine, software shows no problems then maybe the power commander is defective.
Old Mar 22, 2009 | 11:29 PM
HuskerPower
i'm an idiot, the electrical cable under the coil where the spark plug wires came unplugged when i pulled the box out! thanks guys
Fraser19
13
Jan 22, 2019 01:46 PM
Grock23
Nov 16, 2012 10:31 AM
pshaw09
May 24, 2011 09:43 AM
gpp
Nov 22, 2010 07:05 PM
WVNightrain Rider
Aug 4, 2009 08:28 PM
