How To...
Old Mar 30, 2009 | 01:53 PM
mjsawatzky's Avatar
mjsawatzky
Default How To...
Going to be installing new springs and was wondering if there is a trick to removing the fork caps without damaging the finish. Thanks in advance.
Old Mar 30, 2009 | 02:00 PM
lowrider966's Avatar
lowrider966
If your talkng bout the caps on top of the trees I removed mine with an adjustable wrench real carefully. If your talking about the caps on top of the sliders I'm not sure, sorry.....
Old Mar 30, 2009 | 02:07 PM
paul s's Avatar
paul s
http://www.mactools.com/product/tabi...mn08-0139.aspx I ordered the socket, it has an O-ring in it for a cushion, I also put a piece of an old Tshirt on the cap before I put the socket on.
Old Mar 30, 2009 | 02:12 PM
benwiggin2's Avatar
benwiggin2
Thanks for the hot tip last week Paul. NAPA had one in stock. Installed the Ricor's with the Triple Rate Works Performance kit. It's a really nice set up.
mjsawatzky, if you use a socket, it won't damage your finish I don't THINK, but, you could use the crescent wrench with a rag around your cap, but it'll prolly be harder to get back on than with the socket.
Old Mar 30, 2009 | 02:17 PM
thedonthere's Avatar
thedonthere
You can also put some tape around the nut. Best to have another set of hands to help you out.
Old Mar 30, 2009 | 03:24 PM
mjsawatzky's Avatar
mjsawatzky
Thanks Guys. I've never been in there before, i've read the instructions but not too sure what to expect. Is it going to get messy? Any tips on how much fork oil I might have to add? Thanks.
Old Mar 30, 2009 | 03:30 PM
rounder's Avatar
rounder
Just pull the springs out slowly. also be careful the caps are under pressure from the springs. Should not need to add any oil.
Old Mar 30, 2009 | 03:49 PM
paul s's Avatar
paul s
http://www.progressivesuspension.com...rings/3055.pdf My level was low from the factory, with a different spring it changes the level[ tighter wound and larger diameter] In this link they recommend 5.5 inches, that is with forks compressed and springs out.
Old Mar 30, 2009 | 04:33 PM
mjsawatzky's Avatar
mjsawatzky
Thank to all for sharing your wisdom
Old Mar 30, 2009 | 05:58 PM
PKellyMc's Avatar
PKellyMc
From: PacNW; Beacon of Conservatism in a Sea of Liberals.......AZ Snowbird; Just another Conservative
Had my bro apply down force to the cap with a large wooden dowel. Wadded a big rag atop the dowel to save his hands. I stabilized the dowel on the cap with my left hand, swung a 12" Crescent with my right. HAVE HELP! It takes about 50-75 pounds of force to hold that cap down (removal or install), and there were a lot fewer threads than I was expecting, so be ready.
