Starting your Dyna? Clutch engaged or disengaged
Old Mar 30, 2009 | 07:47 PM
jblank37's Avatar
jblank37
Default Starting your Dyna? Clutch engaged or disengaged
Just curious. When in neutral with green light on, I have read where some people have theirs engaged and some don't.
Old Mar 30, 2009 | 07:58 PM
greenyetti's Avatar
greenyetti
I squeeze it when I start, even with a green light, just habit.
Old Mar 30, 2009 | 08:03 PM
motox285's Avatar
motox285
makes no difference
Old Mar 30, 2009 | 08:16 PM
bigmikaele's Avatar
bigmikaele
Nearly always have it in "N", and always have the clutch in just in case. Some times find out that it isn't in "N". When it is in gear (even with the clutch pulled) the bike seems to pull a bit when I start it. No issues though, don't think it matters which way you do it.
Old Mar 30, 2009 | 08:22 PM
Prodriverdon's Avatar
Prodriverdon
Habit to always pull in before starting
dyna rider's Avatar
dyna rider
Default Clutch
I was under the impression that the newer bikes had to have the clutch lever engaged in order to make the bike start. Mine is an 06 and will start regardless. Maybe I'm wrong....Anybody ?
Old Mar 30, 2009 | 08:23 PM
MZBuckeye's Avatar
MZBuckeye
Harley's have no safety disengage do they? If you have it in gear and hit the starter without the clutch, it'll leap forward won't it?
I put it in N and fire, no clutch.
Old Mar 30, 2009 | 08:31 PM
archergodwin's Avatar
archergodwin
"N" = start
"gear" = no start
"gear" + clutch = start
There's a reason for that little switch under your clutch handle on the newer bikes.
Old Mar 30, 2009 | 08:49 PM
ackman1968's Avatar
ackman1968
I always pull the clutch in, you just never know.
Old Mar 30, 2009 | 08:55 PM
p.o_o.h's Avatar
p.o_o.h
Originally Posted by archergodwin
"N" = start
"gear" = no start
Well said!!!
