Maybe its simple...
Old Apr 2, 2009 | 02:19 PM
zird00's Avatar
zird00
Question Maybe its simple...
I don't really know? Could some one explain how to install fork boots. Do you have to completely disassemble the lowers? Pics would be nice.
Old Apr 2, 2009 | 03:12 PM
MZBuckeye's Avatar
MZBuckeye
Fork boots? You mean those little rubber/plastic accordion looking things that cover the tubes above the lowers?
Old Apr 2, 2009 | 03:30 PM
t150vej's Avatar
t150vej
Take the front wheel and fender off. There is an allen-head bolt at the end of each lower in the center where the axle sits. Usually can get them out by hand, but helps to have an impact wrench to spin them out quickly so the slider mechanism doesn't spin too. Then pull the lower off and there you are. Replace your seals and change the fork oil while you're there. You have to take the cap nuts off the forks to add oil.
Old Apr 2, 2009 | 04:09 PM
AdrianVall's Avatar
AdrianVall
What? Why take off the front wheel and all that... I installed mine and it took me 10 minutes.
...take caliper off. loosen triple tree pinch bolts. (make sure bike is strapped down on jack really tight.) When pinch bolts are loosened, pull the forks out. When front end is off, slip fork boots on. Put forks back through tree's, tighten, put caliper on, and DONE.
Brettfullthrottle
Mar 21, 2014 05:10 AM
Dyna_in_the_works
Dec 5, 2010 08:24 AM
meepers
Apr 5, 2010 11:40 AM
2007fxdb
Apr 15, 2008 06:51 AM
neurostudy
Mar 17, 2007 11:23 PM
