Riser help
Old Apr 7, 2009 | 01:49 PM
JYoung189's Avatar
JYoung189
Default Riser help
Has anyone put just risers on their bike? If I put 4 1/2 inch pull back risers on, will I have to get longer cables? Right now I have the stock risers (think 2 inches). Thanks.
JY
Old Apr 7, 2009 | 01:59 PM
bberck's Avatar
bberck
You can usually go up 2-4 inches and make the stock cables work. It can also depend on how you postion the bars.
Old Apr 7, 2009 | 02:02 PM
Centerline's Avatar
Centerline
JY
It could be helpful to inform what bike you are writing about.
Old Apr 7, 2009 | 02:14 PM
Yonaton's Avatar
Yonaton
Not Smart Enough To Be A Member of HDF
I put 4 1/2 inch risers on my '09 FXD and only had to pull some wiring from inside the neck frame (you should have just enough 'extra' in there. Pull gently, don't yank!). Front brake line 'seemed' a little too tight at first, but turned out it's fine.
Old Apr 7, 2009 | 02:59 PM
JYoung189's Avatar
JYoung189
The bike is a 03 FXDX.
Old Apr 7, 2009 | 03:12 PM
JRK5892's Avatar
JRK5892
nope but you will have to re route your clutch cable and re bend your brake lines
Old Apr 7, 2009 | 03:21 PM
JYoung189's Avatar
JYoung189
How hard is it to re route clutch cable and re bend the brake lines? Does it require any special tools?
Old Apr 7, 2009 | 03:48 PM
JRK5892's Avatar
JRK5892
just soft hands man... soft hands... to re route you have to unhook the cable at the grip, then figure out how to run it where you will have the most slack and still get to where you want it... turn bars in both directions to ensure it does not get caught up... good to go
Redleg by God!
Nov 7, 2014 06:16 PM
pewter sb
Apr 17, 2011 04:14 PM
TSD1959
Mar 6, 2011 09:47 AM
loosnut
Feb 13, 2011 07:50 AM
capnjim01
Sep 30, 2006 11:29 PM
