Oil Filter cross reference
Old Apr 8, 2009 | 05:55 PM
ettev's Avatar
ettev
Default Oil Filter cross reference
Will the longer H/D filters listed for 1991-98 Dyna models (part #63813-90) work on newer Dyna models (specifically a 2003 FXDWG)?
Old Apr 8, 2009 | 06:00 PM
Gary7's Avatar
Gary7
It will fit, but I would not use it. The older filter does not have an ADBV, which the filter for the TC does. Harley lists the later filter as an "upgrade" for the older, but the older filter is not listed as a substitute for the newer. I think the TC needs the ADBV.
Old Apr 8, 2009 | 06:09 PM
ettev's Avatar
ettev
Gary7,
Thanks.
Old Apr 9, 2009 | 08:41 AM
capnez's Avatar
capnez
I use Purolator PL10241 it is gold color it has the spec you want(10 micro and other ) for 2003 twin came at great price $5.88 at advance auto. I use it on mine.
Old Apr 9, 2009 | 08:52 AM
Gary7's Avatar
Gary7
Purolator does not list the PureOne PL10241 as a substitute for the OEM Harley filter. In fact, Purolator explicitly warns people NOT to use PureOne filters on motorcycles because they are too restrictive.
Old Jul 13, 2010 | 10:23 AM
capnez's Avatar
capnez
It fits the exact specs as one for 1999 -2004 It is not good for an evo and shovels too restrictive. 10 microns is what mine calls for.I think it will not fit yours as you need 5 microns.
Old Jul 13, 2010 | 11:03 AM
JRK5892's Avatar
JRK5892
i got a wix from autozone that works i can look for the numbers on it later if you wnat
Old Sep 30, 2014 | 05:28 PM
ddmyers's Avatar
ddmyers
Stage I
Default Oil Filter for 103 Twin Cam
Ride an 11' Road Glide with 56,000 miles. Use Purolator PureOne filters ONLY! PL10241. Have been most Happy with this filter, I do Not use synthetic oil but rather Castrol 20-50. Change oil at 3000 miles and filter. Have ridden over 200,000 motorcycle miles without an issue!
Oil filter is $7 at Advanced auto, oil is $16 for 5 qts. at walmart.
RA51
Oil Archive (no new posts)
Apr 17, 2017 06:49 AM
DeaD SpacE
Jul 15, 2016 07:36 PM
rocket23
Mar 12, 2012 09:52 PM
getty30188
Jun 19, 2011 04:44 PM
ezryder1962
Apr 27, 2009 11:53 AM
