Handlebar/Fork Bag mounting...
Old Apr 12, 2009 | 08:35 PM
DeathProof72's Avatar
DeathProof72
Default Handlebar/Fork Bag mounting...
I know that this may sound stupid, but any suggestions where else to attach a fork bag other than above the headlight? I took mine off since I am having my handlebars swapped out, and saw that from being above the headlight for only a month, it had marred the finish a bit..
Old Apr 12, 2009 | 08:41 PM
archergodwin's Avatar
archergodwin
Off the bottom tree.....
Old Apr 12, 2009 | 08:43 PM
bberck's Avatar
bberck
I orginally had mine above the headlight, but like you after it marking up my risers and ruining the finish on my headlight I took it off.
I made a hard mount from a T-brace and mounted it under the headlight using the headlight mounting bolt. This made it very secure and also kept it from rubbing anything. I later moved it down on the frame using the same hard mount just bending it more to make it work.
Brace I used (I bent the short end 90 degrees, then cut a hole for the long end to go through the bag. I then uses to bolts to mount the brace to the bag.)
hard mounted to forks
Its current location
Old Apr 12, 2009 | 08:46 PM
Royce's Avatar
Royce
Ditto. I put mine on my Sporty with no problems for 10 years. That's where it is on my FXDC; after 1.5 years, no problems.
Old Apr 12, 2009 | 09:21 PM
DeathProof72
Only problem is, my bike has handlebar mounted turn signals still, so there wouldn't be anything to hold the bag up...
Old Apr 12, 2009 | 09:23 PM
DeathProof72
I thought of that location, but do you ever have any problems with dirt and dust getting in your bag there?
Old Apr 12, 2009 | 09:28 PM
HDDyna2006's Avatar
HDDyna2006
I have mine screwed thru front frame engine guard mounting hole.
Old Apr 12, 2009 | 09:44 PM
traveler's Avatar
traveler
I'm looking at laying mine across the handlebar clamp right below the speedo.....since I'm getting the "Fork Bag Stereo" From Joe on here, I want it to be where I can adjust my MP3 player and kick back and listen to the tunes....
I will probably get another and put it down low over the front motor mount.
~Joe
Old Apr 12, 2009 | 09:46 PM
anubisss's Avatar
anubisss
If you mount it under the light be wary as it may hit your fender on big bumps. Just a thought.
Old Apr 12, 2009 | 09:48 PM
BluBob's Avatar
BluBob
Use the brake line retainer bolt under the bottom tree to attach a rigid angle mount. The bag screws to that with a backing plate made of plastic stock inside. It's bulletproof and will not rattle, rub, or fall off.
Attached Thumbnails Handlebar/Fork Bag mounting...-fork-bag-mount-compressed.jpg
