What cams for my 06 BOB??
Old Apr 14, 2009 | 07:57 PM
A-10 KChawg's Avatar
A-10 KChawg
Originally Posted by moparnut426
Im planning on a cam swap for my BOB, I have a screamin eagle race tuner, I have the thunder header, have a kuriakin pro charger intake breather, and all Im really after is a little better mid range, and a better exhaust note. In wyoming I had it dynoed with 87hp as it sits, and I want a little more of course. I want to ditch the crappy factory chain and tensioner, and go gear drive, but I am torn between witch lit to order.
I also dont want to dick with having it re tuned and was told some cams just have more lift, and tuning is not needed, is that true?
Kasey
I was wondering the same original question. I have alot of warranty left on my bike. Will buying Andrews or Woods and not SE void my warranty?
Old Apr 14, 2009 | 08:37 PM
chad peterson's Avatar
chad peterson
Depends on your dealer...they're all different on this subject! Some will honor the warranty if they do the install, others won't!
Old Apr 14, 2009 | 08:47 PM
FXDF103's Avatar
FXDF103
Only guaranteed way to have hotrod parts and not have warranty problems is to have them installed by the stealer at the time of purchase. Otherwise it's hit and miss.
Which is why I paid the stealership's extortion prices for my stage 3 kit, install, and tune. So there is no question about the warranty.
Old Apr 14, 2009 | 08:54 PM
Dyna-Asa's Avatar
Dyna-Asa
he is wanting to go with gear driven cams, is there some machine work needed on the crankshaft? (something to do with endplay?)
-Asa
Old Apr 14, 2009 | 09:03 PM
chad peterson
Just need to check it with a dial indicator for run out. Mine was way out so I had it trued and welded to run gear driven cams! Depending on funds he may cosider stickin with the new chain drive set up...it's alot better than it used to be!
Old Apr 14, 2009 | 09:10 PM
Dyna-Asa's Avatar
Dyna-Asa
thanks, "run out" thats what I looking for not "end play"
Old Apr 15, 2009 | 10:44 AM
moparnut426's Avatar
moparnut426
Even if there is excessive run out, im gonna fix it and run the gear drive. I feel safer with that. I run a chain in the stroker in my Demon, but its a Billet gear and spendy chain, handle anything on that engine, my harley is a different deal.
THanks guys
Kasey
Old Apr 15, 2009 | 05:43 PM
chad peterson
Don't blame ya one bit...I did the same thing, nothin better than geardriven cams! But for those of you that can't afford or don't have the mechanical skills to fix it if ya need to, the new chain set up is pretty damn good!
Old Apr 15, 2009 | 06:39 PM
jsbridgew's Avatar
jsbridgew
Headquarters "hurricanes"
Old Apr 15, 2009 | 09:22 PM
ackman1968's Avatar
ackman1968
Im planning on doing all this myself. My buddie has the tools for pressing out the cams, and I have done several cam swaps in bikes, but never a twin cam. All I need is a good cam selected for my application. Nice broad curve, and a good note.
I can trailer it to my dealer and have it tuned
Kasey
You won't need your buddies tool for pressing out the cams, they slide right out. You will need his bearing tool if you replace the inner bearings though.
666streetbob
May 24, 2016 08:17 AM
icebite1
17
Aug 19, 2010 01:18 AM
jcsurf
Exhaust System Topics
Mar 20, 2009 06:20 AM
flea402
Oct 13, 2007 12:54 AM
yoopermjm
Feb 20, 2007 09:28 PM
