yet another problem
Old Apr 20, 2009 | 02:47 PM
jfm5's Avatar
jfm5
Unhappy yet another problem
hi all, i will be going away to a bike rally a week on saturday so i decided to install the bike rack ready to put the camping stuff on. only when i came to remove the fender mounting bolt just before the rear turn signal on 02 wideglide wtf it spins but doesnt unscrew the air in my garage suddenly turned blue. i tried holding it with a pair of pliers the other side but theres nothing to hold onto to stop it spinning. has anyone also come across this problem or any ideas what i can do i have a feeling i will need to drill it out. help
Old Apr 20, 2009 | 03:33 PM
Trippster's Avatar
Trippster
Default Same problem
I have an 07 Wideglide and I ran acrass the same problem. While I went to start to break the bolt loose it went (snap).and it broke. I went ahead and got the other bolt off and inside the fender there is a flat bar that has threads on each end for the bolts to go into. Same problem nothing to hold onto. Once I took that bar out (not sure what its called) I was able to push the bolt from the inside and get enough room to cut it off with a hacksaw. I don't know if an 02 is the same as an 07, but that was how I had to do it. Hope this helps and good luck.
Old Apr 20, 2009 | 03:47 PM
maddghost's Avatar
maddghost
Marky is right i had to saw one off last year too. I suppose they have spare ones at HD ,but can't confirm because I had a couple spares from saddlebags. incidentally,I have broken tw,but only had to hacksaw 1 of them.
Old Apr 20, 2009 | 04:13 PM
DSnoopy's Avatar
DSnoopy
Same thing happened on my belt guard. They seem to have an over excited person or machine on the assembly line.
Old Apr 20, 2009 | 04:16 PM
GREENOHAWK69's Avatar
GREENOHAWK69
Just an FYI - instead of using a hacksaw; buy a Dremel with the metal cutting attachments and you'll go through that metal almost like a hot knife through butter. I've hemmed and hawed on buying one, but after the first time using it, I couldn't believe I didn't get one earlier.
Old Apr 20, 2009 | 04:39 PM
recon_sct's Avatar
recon_sct
+1 best tool I've bought, should have picked one up a long time ago!!!!
Old Apr 20, 2009 | 06:07 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
That bolt is the one by the shock upper mount, when I put my saddlebag docking hardware on my 02 Dyna Superglide there was a nut on the backside. Don't remember if it was a 1/2" or 9/16" (you figure out the metrics). Same thing for the turn signal mount.
Dannyrider
Sep 21, 2014 04:15 AM
ripto
Sep 7, 2010 12:26 AM
scripture187
Nov 2, 2009 05:44 PM
57RebelRocker
General Topics/Tech Tips
Jan 22, 2009 07:41 PM
joetst2
May 28, 2006 09:32 PM
