LOUD shiff
Old Apr 28, 2009 | 07:34 PM
mirror's Avatar
mirror
Default LOUD shiff
It's a new last september 09 super gulid had forward controls put on . But this year just sounds loud when it shiffs all gears. is it just me??? or is this a harley thing???
PS
All oils have bin changed
Old Apr 28, 2009 | 08:30 PM
SuperFastGlide's Avatar
SuperFastGlide
pretty normal, mine gets louder as the clutch needs adjusted...
Old Apr 28, 2009 | 09:06 PM
jimw411's Avatar
jimw411
Run Bel Rey Gear Saver in the trans, it will quiet it down. Also shift while you pull in the clutch instead of pulling in the clutch and then shifting.
Old Apr 28, 2009 | 09:08 PM
Bluesrider's Avatar
Bluesrider
Talking
PS
No more beer for me tonight
Old Apr 28, 2009 | 09:11 PM
Double00Aught's Avatar
Double00Aught
Good...I thought it was me
Old Apr 28, 2009 | 11:14 PM
2007fxdc's Avatar
2007fxdc
Fluids have been changed but changed to what - same old harley stock fluids? My indy swapped all mine out for Amsoil synthetic in all holes and it now shifts quieter and smoother. Much easier to find neutral even.
Old Apr 29, 2009 | 11:23 AM
mirror's Avatar
mirror
It was changed at Harley they said it was synthetic. Ill check out the clutch adjust Let you now
Thanks
Old Apr 29, 2009 | 01:01 PM
mirror's Avatar
mirror
Check all the oils it all good . How hard is it to ajust the clutch?? the manual tells you nothng. Isee where the cable gos in there is a crome cover. HELP??
Old Apr 29, 2009 | 07:49 PM
Double00Aught
mine shifts hard as well and neutral is tough to get since I swithed to Syn3. I may go back to gear grease.
Old Apr 29, 2009 | 08:03 PM
mirror's Avatar
mirror
Thanks
