Laced wheels
Old Apr 29, 2009 | 02:01 PM
wvsuperg's Avatar
wvsuperg
3rd Gear
Default Laced wheels
Anyone know if laced wheels from an 09 fxdci will fit an 06 fxdi?
Old Apr 29, 2009 | 03:22 PM
thedonthere's Avatar
thedonthere
The bearings are different. 06 = 1"(25.4mm) 09 = 25mm You can probably swap them.
Old Apr 29, 2009 | 03:25 PM
dyna07custom's Avatar
dyna07custom
I believe the axles are different size
Old Apr 29, 2009 | 03:52 PM
wvsuperg's Avatar
wvsuperg
3rd Gear
So new bearings and axles? I knew the rotors were drifferent but wasn't sure about anything else.
Old Apr 29, 2009 | 06:25 PM
jmpancoast's Avatar
jmpancoast
Its gonna be new axles OR new bearings. The 25mm axle should work in your sliders and should be easier and cheaper than replacing the bearings.
Old Apr 29, 2009 | 08:15 PM
wvsuperg's Avatar
wvsuperg
3rd Gear
Thanks, I wasn't sure what I was getting into but wanted laced wheels. jmpancoast,is the front on your bike a 19"or 21"?
Old Apr 30, 2009 | 04:20 AM
jmpancoast's Avatar
jmpancoast
Its a 21". I used a hub from an 07 Street Bob and laced a 21" rim to it.
Old Apr 30, 2009 | 08:01 AM
MarksBOB's Avatar
MarksBOB
A note on bearings,
It's not always easy to swap out 25mm to 1". (ask me how I know )
the 25mm are only 15mm wide and the 1" are 21mm wide some newer hd wheels can't
take a bearing that is 21mm wide.
options are , run non standard bearings ( 1"x 15mm wide ) alot harder to get hold of.
swap to 25mm axles, you also need all new spacers to go with it .
If you require the part No for the non standard bearings , PM me.
Old Apr 30, 2009 | 12:19 PM
wvsuperg's Avatar
wvsuperg
3rd Gear
I stopped by the stealership today and checked on bearings and had no luck.They didn't know if they could get bearings and they also said I would probably need custom spacers. Then there is the issue of the rotors.They weren't sure what to do with the rotors if they could get some to work.
I'm bummed. I got a sweet deal on wheels with less than 100 miles on them but It might be easier and cheaper to sell them and go for wheels made to fit my bike.I don't know.
jake2351
Wheels/Tires
Jul 1, 2019 01:05 PM
06flhri
May 24, 2016 05:52 PM
haak30
Mar 17, 2015 08:58 PM
kelinsky1
Wheels/Tires
Feb 23, 2010 01:28 PM
Gary7
Aug 27, 2009 10:16 AM
