View Poll Results: Front or Rear suspension first?
Front (Intiminators)
28.57%
Rear (Ohlins or Works)
71.43%
Voters: 14. You may not vote on this poll
Front or Rear first?
Old Apr 29, 2009 | 08:45 PM
DeathProof72's Avatar
DeathProof72
Default Front or Rear first?
I know that this may be a silly question to most, but personally I just need a few opinions and some advise on what to do first. While I have already decided that I need to do something to improve both my front and rear suspension, right now, I can only afford to do one of the two.
Rear, will either be going with an Ohlins, or Works, up front, gonna go with an Intiminator.
What I really wanted help with is not so much opinions on these products, but with which would make the greatest amount of difference if done by itself first in terms of ride and handling improvement. Also, if possible, share the reason for your choice. Thanks..
Old Apr 29, 2009 | 08:50 PM
BIGDADI's Avatar
BIGDADI
If you can only afford one, do the rear first and at least change the front fork oil for a improved ride till you can afford springs.
Old Apr 29, 2009 | 09:09 PM
Dyna-Asa's Avatar
Dyna-Asa
Front first IMO, I just can't stand the squishy forks + upgrading should also help you brake better
Old Apr 29, 2009 | 09:22 PM
madden23's Avatar
madden23
The front is the weakest link, do that first, but you won't appreciate the change in the front fully unless you change the rear, sorry they work in tandem.
Old Apr 29, 2009 | 09:54 PM
MZBuckeye's Avatar
MZBuckeye
Tough call as they both need to be done, but I'd go with rear first to save on bottoming out and your lower back.
Old Apr 29, 2009 | 10:29 PM
ericsenf's Avatar
ericsenf
This is really going to depend on your riding style. If you do a lot of twisties, the front is key. Springs, fork oil, and fork brace. If it's more casual cruising, the rear could provide a smoother ride. What ever your riding style, doing both at the same time and matched to your style of riding.
For me, it was front, rear, rubber, and brakes all at the same time 2 winters ago and I'd do it all again.
cycle7447
2014-2024 Touring Models
23
Sep 17, 2016 07:40 AM
streetpep
May 26, 2014 10:21 PM
HELLBENT48
Jan 5, 2012 11:44 AM
xlc06
May 26, 2007 02:07 PM
Jello
Screamin Eagle CVO Models
May 25, 2007 09:35 PM
