emergency tyre repairs
Old May 3, 2009 | 05:31 PM
phog light's Avatar
phog light
Default emergency tyre repairs
does anyone carry or has anyone used an emergency tyre repair aerosol.the kind thats supposed to inflate and seal a punctured tyre.would they work on a spoked wheel with an inner tube?? it says on the can that they work but i,m not so sure
cheers
mick
Old May 3, 2009 | 05:46 PM
coachwes's Avatar
coachwes
I havent seen it work on an inner tube style tire only tubeless . It may pump up the tire and hold for a short emrgency run but cant see it patching a tube for a reliable long run . You say it says it can pump up and hold on a spoke rim and tube type it would be new to me . I have seen slim to tempary hold on a small leak, to get you off the road but it will shake you to death on a bike do to throwing it way out of balance lol.
Old May 3, 2009 | 07:31 PM
rdondes's Avatar
rdondes
If your tube goes flat, you are ****ed. No inflate-a-can can help. Time to call the tow truck and take it to a shop for new tire, tube and rim band.
Old May 4, 2009 | 12:01 AM
Other Sheep's Avatar
Other Sheep
I used a can in my 99 Heritage three different times. It worked great twice and allowed me to get home and take it to the shop the next day. Third time the tube got totally wasted so nothing was going to help. So I carry a can in my saddlebag.
Old May 4, 2009 | 12:26 AM
maddghost's Avatar
maddghost
I wouldn't trust it- not on two wheels ,but if it gets ya home cheers!
Old May 4, 2009 | 01:47 AM
jimw411's Avatar
jimw411
Fix a flat is bad for aluminum, it corrodes it. Tire plugs are the way to go. I don't worry about it, i just check my pressure regularly and if i get a flat i have AAA premier with RV/ Motorcycle So i can just get a tow if i need it.
Old May 4, 2009 | 03:43 AM
Naz_Man's Avatar
Naz_Man
I used fix-a-flat on my spoke wheel once and it started coming out around the spokes, I didn't make it a mile and it was flat again.
This chit don't work on tubes!
I had my brother come get me with the trailer, took her home and fixed the tube with a bicycle patch kit.... worked great, no need to change the tire, straps and tube!
Naz
Old May 4, 2009 | 06:56 PM
vet767's Avatar
vet767
Unfortunately you can not plug a tube type tire and except for some very pricet laced wheels, the all have tubes
markdavidson
2014-2024 Touring Models
Jul 18, 2016 09:44 AM
Ndoggct
Sep 28, 2015 05:07 AM
grandpatim
Apr 14, 2011 04:30 PM
elevenbravo78
Apr 19, 2010 12:14 PM
highbars92
Jul 9, 2008 08:33 PM
