Dna 21" wheel valve stem help!
Old Sep 27, 2015 | 03:39 PM
Ndoggct's Avatar
Ndoggct
Default Dna 21" wheel valve stem help!
Hey guys ive developed a leak coming from my valve stem..the rim is 21x2.15 52 fat spoke..im not sure if there is a tubed tire or not..its a metz 88 tire..can i put a tubed tire on this rim or tire if valve stem is bad? Thanks greatly
Old Sep 27, 2015 | 08:18 PM
escalade6103's Avatar
escalade6103
if its the metal valve stem that it came with then you can tighten it up. its probably the rubber gasket that is cracked. i had the same thing happen to mine. i rode with it like that for probably 10k miles. i would recommend getting a new stem or a tube put it. they do not come with tubes. yes you can put a tube in it even if it says tubeless. a lot of people with spokes put tubes in theirs since the spokes can leak if the seal around the rim covering to spokes goes bad.
Old Sep 27, 2015 | 08:37 PM
RANGER73's Avatar
RANGER73
You can put a tube in a tubeless tire if the tire's still good.
Old Sep 28, 2015 | 05:04 AM
Ndoggct's Avatar
Ndoggct
Thanks guys
Old Sep 28, 2015 | 05:07 AM
Ndoggct's Avatar
Ndoggct
Nut was loose by hand which i tightened to slow leak a little but there is what looks like gasket material coming up through hole so i am guessing the gaskets delaminating..i was hoping on throwing in a tube but heard u couldnt fit a tubed valvestem through opening of rim
Ndoggct
Sep 26, 2015 08:12 PM
ib5150
Dec 4, 2013 10:26 AM
tmac00333
Jul 29, 2013 10:43 AM
elevenbravo78
Apr 19, 2010 12:14 PM
Tatt22
Apr 14, 2009 10:33 AM
