sipping problem
Old May 9, 2006 | 03:54 PM
sporty2003's Avatar
sporty2003
Default sipping problem
has any body had any trouble with the seam between the motor and the tranny sipping oil ?on a 05 dyna the dealer says it is normal and want me to watch it. if it gets worse then they will take care of it . so what do you all think. it is under warranty.
Old May 9, 2006 | 04:07 PM
rh8234's Avatar
rh8234
Default RE: sipping problem
This has been discussed before. I understand that this is a common thing with Dynas and is most noticable on the ones with silver cases. The seam between the engine and trans get a little dark oil stain on it. I've been told by dealers that this is not a leak as there is no oil in that area and no gasket between the trans and engine. It could be machining oil left over from the manufacturing process. As I've mentioned before, I clean ming every couple weeks with brake cleaner and the wife's tooth brush. Looks good as new, but the wife's teeth are getting a little stained.
Old May 9, 2006 | 04:10 PM
sporty2003's Avatar
sporty2003
Thanks so that is why the dealer is not sweating. thanks again.
Old May 9, 2006 | 08:05 PM
veniculum's Avatar
veniculum
I have the same thing on my 06 WG. It's very little, and I noticed it once...there was quite a bit..since I cleaned it, it's only be a tiny bit each time I ride. I'm going to keep an eye on it...I'm hoping that the explanation above is the correct one..but I'm still going to bring it up the next time I go in for service.
I wish I would've thought of the toothbrush and brake fluid. Is brake fluid toxic? We just took out a new life insurance policy
Todd
Old May 10, 2006 | 12:14 PM
rh8234's Avatar
rh8234
NOT BRAKE FLUID!!!!! IT WILL DO SERIOUS DAMAGE. USE BRAKE CLEANER. It comes in spray can and you can get it at any auto parts store or walmart or kmart.
Old May 10, 2006 | 01:13 PM
veniculum's Avatar
veniculum
ORIGINAL: rh8234
I gotcha...that was my mistake. I meant to say brake cleaner..but I was too busy trying to make dead wife jokes
Todd
dakotacrk
Aug 29, 2007 08:43 AM
cravenc
Aug 20, 2007 11:18 AM
bulldogmoe7
May 28, 2007 06:02 PM
UltraSwampy
May 25, 2007 12:12 AM
anubisss
Apr 10, 2006 11:40 PM
