More ponies..help needed
Old May 9, 2009 | 10:18 PM
redrubicon2004's Avatar
redrubicon2004
Andrews 26 and 37 are both bolt in. The 26 would be good for a stock motor, while the 37 would also work in a stock motor but wouldnt give you its all till later mods can be done.
If you have a carb bike. I would try and stay under 10:1 compression so you dont have to worry about pinging issues or having to run octane booster. Also, Mine at 9.8 likes the compression releases....just something to think about.
Mine has a Andrews 37 with a 95" and head work. 9.8:1 compression (SE flat top pistons with 81cc heads) Headwork was done by a very reputible guy in Chicago.
Old May 9, 2009 | 11:37 PM
DOUBLE-D-LOWRIDER's Avatar
DOUBLE-D-LOWRIDER
my 03 fxdl..w/se air, vh big radius exhust, se ignition...as it is set up now...
looking at your build..pretty much where i want to go.so i could start w/ the
95" kit first...next do the 37 cams.., mik 42...maybe head work down the road...would see numbers similar to yours..that would be great...thanks much...
Old May 9, 2009 | 11:43 PM
DOUBLE-D-LOWRIDER
where do you think would be the best place to start..since i probally could
only do a bit at a time..thanks for all the info..this is new to me..and wanna
do it right..
Old May 9, 2009 | 11:49 PM
DOUBLE-D-LOWRIDER
i have a set of se 211 cams that were given to me w/less than 2000 miles on them..
what do you think about them..there sitting in the garage ????????...
Old May 10, 2009 | 08:58 AM
Wireguided's Avatar
Wireguided
Send them too me and ill get rid of them for you....
Old May 10, 2009 | 09:54 AM
DOUBLE-D-LOWRIDER
thanks randy !!!....i am wondering if they would work well.with my
somewhat stock 03 fxdl ??? se air, se ignition, vh big radiuss exhaust...
new to me this buid stuff !!!!!!!!!!!!!!!!...this is a great site !!!!!!
Old May 10, 2009 | 10:08 AM
DOUBLE-D-LOWRIDER
Default 211 cams, 95" build ?
any body that can give me some insight on se 211 cams ? i have a 03 fxdl
se air, se ignition, vh big radiust exhaust...want to build it up to a 95"
a bit at a time, cams and big bore kit, any ideas, and will these cams work well for me, as a mostly stock 88...any and all help suggestions...greatly
appreiciated..this build stuff is new to me..thanks dd
Old May 10, 2009 | 10:11 AM
archergodwin's Avatar
archergodwin
Didn't you get enough info on your previous thread on this very subject?
Old May 10, 2009 | 10:13 AM
DOUBLE-D-LOWRIDER
looking for insight on the 211 cams...
happy mothers day..lol
Old May 10, 2009 | 10:19 AM
archergodwin
Yes, I can be a mother...
