More ponies..help needed
Old May 9, 2009 | 07:45 PM
DOUBLE-D-LOWRIDER's Avatar
DOUBLE-D-LOWRIDER
Nice..mine much the same..i have the all black paint set..corbin seat...
Other than your air ..very much the same...except the ponies...thanks
Old May 9, 2009 | 07:48 PM
SC-Longhair's Avatar
SC-Longhair
I know Sniper77 just did a 95", cams and headwork. I can't touch him on my 96". He just walks away....quickly.
Old May 9, 2009 | 07:53 PM
redrubicon2004's Avatar
redrubicon2004
Originally Posted by SE catalog
SE-211 CAM KIT
This camshaft works great with 103" and larger engines
with free flowing intake and exhaust. This bolt in camshaft
works well with stock heads and high compression pistons.
It increases mid-range torque and top end power. For race
application only.
I'm not a big fan of SE cams.
I would pick a Andrews 26 if you are going to stick with a mostly stock engine, 37 if you are going to modify. The 37 is a really good all around cam!
Engine work is something you really want to sit down and plan out. You have to decide first how far you wanna go and how much you want to spend. I wouldnt plan a build around a cam, but rather what you want to get out of the engine. Once you figure that out, pick your cam and design the build.
Where do you live? Just trying to get an idea where you are, you might have some excellent builders or machine shops in your back yard.
Old May 9, 2009 | 08:00 PM
DOUBLE-D-LOWRIDER
I live in central wisconsin, wausau...i would like to just go up to the 95"..maybe not the cams right away..
Or could i ..or should i start w/
cams...can only do one or the other this year..is the andrew 26 a bolt in cam..? Is it a low to medium torque cam ...just want a starting point..where the best place to start...thanks dd
Old May 9, 2009 | 08:28 PM
dyna rider's Avatar
dyna rider
Default SE 211 Cams
My first engine mods were a 95 inch kit with HC pistons, 211 cams,and a S.E. race tuner. It made 85 HP with 93 Ft lbs of torque. Not great numbers but the torque started down low on the rpm range and went well to 5500 revs.All in all, it was a lot more fun to ride than a stocker.
Old May 9, 2009 | 08:34 PM
DOUBLE-D-LOWRIDER
Sounds like the place to start..going to the 95"...cams may have to wait..tell next year..is the high comp. Pistons a better build. Or whats the difference..thanks
Old May 9, 2009 | 08:50 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Sometimes you can find a 95" kit with SE203 cams, SE cams are like which oil is better, I just put the 95" kit with the 203 cams and it really woke up the motor. The cams come in around 2500 rpm and it just pulls like a locomotive especially two up. I have a SE/K&N air filter setup and low restriction slip-ons. The carb has been warmed up a little also. I might be wrong but I thought the 211 cams work best with the 103" kit which would require a stroker flywheel when starting with a 88" engine, I could be wrong.
Old May 9, 2009 | 09:02 PM
DOUBLE-D-LOWRIDER
I've done alot of research..and if im not mistaken the 211 work..but theywork better w/more comp.,,,,before i move on..i'll for sure have to look into it much more...any adise from all you hd vets...is great
Old May 9, 2009 | 09:52 PM
blkfalc4's Avatar
blkfalc4
You could just put an Andrews 26 in it for cheap, it's bolt in. Give ya a little more of what your looking for without a big price tag.
Old May 9, 2009 | 10:11 PM
DOUBLE-D-LOWRIDER
good place to start..thanks..save some $..bump it up to 95" next winter..thanks
