Differences
Old May 13, 2009 | 11:53 AM
stef142's Avatar
stef142
Default Differences
Hi, this morning I sat on a '99 FXDX and I found that the rider position is a lot better than on mine '05 FXDX for my height (5.8 feets): the handlebar is nearer to the seat of 1 1/2" due to a shorter tank. Anybody knows if the frame is different too?
Stefano
Old May 14, 2009 | 02:33 PM
08fxdf43202's Avatar
08fxdf43202
I think the Dyna frame was changed in 04... or was it 06?
Old May 14, 2009 | 03:16 PM
OrangeTJ's Avatar
OrangeTJ
The big change to the frame was in 06. The 04's and 05's (well, at least I think the 04's are included) had a longer tank than previous years and slightly shorter seating area as a result. Easiest solution to the issue at hand would be to get a seat that moves you forward an inch or so. I know that on my 05 FXDC, the Sundowner does this when compared to the stock seat. it's a noticeable difference and the bars feel significantly closer and slightly lower relative to the seating position.
Old May 14, 2009 | 03:38 PM
Handycam's Avatar
Handycam
You can get a Reach seat, it moves you up an inch.
Old May 14, 2009 | 03:44 PM
PKellyMc's Avatar
PKellyMc
From: PacNW; Beacon of Conservatism in a Sea of Liberals.......AZ Snowbird; Just another Conservative
I had a Reach seat...Awful! Drapes your "boys" over the back of the tank. I rode 100 miles up to the Olympic Peninsula to visit friends one day. By the time I got there, I was SERIOUSLY dreading the 100 mile return trip. Bought a HD Touring seat (wonderful) and sold the Reach here or on ebay. Just my $0.02.
Old May 15, 2009 | 02:52 AM
stef142's Avatar
stef142
So, do you know if it's possible to mount the earlier shorter tank on my 2005?
Old May 15, 2009 | 10:30 AM
OrangeTJ's Avatar
OrangeTJ
It may be possible, but that seems like the most expensive possible solution. Either bars with more pullback or a Sundowner seat should put you in pretty much the same spot as you felt on the 99.
sajor
Nov 18, 2014 04:19 PM
tripn88
Sep 3, 2012 11:04 PM
RPS1981
May 14, 2011 08:26 PM
ord sgt
Aug 9, 2009 05:23 PM
Strgzr
Mar 11, 2009 08:51 PM
