Engine Trouble - Wanna Help?
Old May 16, 2009 | 05:18 PM
marinepilot81's Avatar
marinepilot81
Default Engine Trouble - Wanna Help?
Here are the specs: 08 Fatbob, 12,000 miles, Wood TW6-6 Cams (1500 miles).
Ok, so a few weeks ago I gunned it to pass a car and noticed a horrendous racket come from the engine once I got back down to cruising RPMs. It went away, but now returns every time I go above 4K on RPMs.
It will go away after different amounts of time, return if I hit the engine hard, give me tons of noise, audible exhaust change (popping plus increased RPM), check engine light, then go away at some point.
The dealer told me not to worry about it...could be lifters...not under warranty because of the cams, and go away.
Any thoughts?
Old May 16, 2009 | 05:44 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
I would do an oil pressure check on your engine first to make sure you are getting oil to the top end. Then you want to be sure the noise you are hearing is not detonation as your timing may be off and you could do some serious damage. If both of those check out then you might consider getting a different set of rocker arms and lifters that go with your cams.
Old May 16, 2009 | 07:48 PM
man4mopar's Avatar
man4mopar
Check engine light comes on and goes out..... so what was the code or codes?
The dealer could very well be correct and your lifters are not holding oil at higher rpms. If that is the case I wouldn't be surprised if new hydraulic lifters still acted the same and solids cured the problem. Solids are always superior in performance vs hydraulics, downfall is they need to be adjusted every so often.
Old May 17, 2009 | 09:45 PM
marinepilot81
So I noticed the engine light comes on when I'm going uphill or stopped at a light on a hill. How do I get the codes? Will my Thundermax do it?
Old May 17, 2009 | 09:53 PM
archergodwin's Avatar
archergodwin
I would think that tuner you would be able to retrieve DTCs.
Old May 17, 2009 | 11:23 PM
marinepilot81
The check engine light comes on when going uphill. Thundermax doesn't show any faults...so what's next? How do I figure out what's wrong here?
Old May 17, 2009 | 11:34 PM
archergodwin
Does the Thundermax cause the CEL to come on, in some fashion for error codes?
My first thoughts are pre-detonation... but that doesn't really hold for sitting at a light. Could be different reasons tho. Sitting at the light could be low oil pressure. While going uphill could be pre-detonation (knock).
As mentioned before, I'd get your oil pressure checked. Low oil pressure could be indicative of some really bad mojo going on.
JaboIam
Jul 8, 2018 01:28 PM
spizzyman
Jun 27, 2010 07:50 PM
Modee1245
Sep 24, 2009 01:28 AM
fatmouse
Jul 20, 2007 10:17 PM
baron3547
May 5, 2007 02:18 AM
