Longer Kick stand???
Old May 17, 2009 | 09:14 PM
crsowa's Avatar
crsowa
Default Longer Kick stand???
So I just put on my new Progressive 440's on yesterday and they are 1/2" longer than stock. I noticed that now when I put the bike on the jiffy kickstand, it seems to lean over a little more than it used to. What I want to know is:
Is there a longer kickstand to help remedy this problem? or do I have to buy lowering blocks or something???
Thanks again guys...
Chris
Old May 17, 2009 | 09:16 PM
LOUDAZZFATBOB's Avatar
LOUDAZZFATBOB
JP cycle has shorter ones.............maybe they have longer ones as well?
Old May 17, 2009 | 09:39 PM
SuperFastGlide's Avatar
SuperFastGlide
it will be fine like that... i put 2.5 longer forks on the front of mine and it leans alot more than before, but its really stable...
Old May 17, 2009 | 09:52 PM
BluBob's Avatar
BluBob
I have the opposite problem from lowering the rear an inch and the front about 1/2, but I only worry about it when I have to park on a lean to the right. I bet you would be okay unless you had to park with downhill to the left.
Old May 17, 2009 | 10:21 PM
Centerline's Avatar
Centerline
Chris
I have 1/2" longer than stock 440's on mine, and it leans over a little bit more on the stand, but has been stable on the stand w/no problems. I do try to park it on mostly level surfaces or the most advantageous side of a grade.
Old May 18, 2009 | 09:41 AM
Slipstrm's Avatar
Slipstrm
I took mine off and heated it with a torch & bent it a little straighter and now its perfect.
Old May 18, 2009 | 09:43 AM
rounder's Avatar
rounder
you raised it to superglide/wideglide height. Will be fine as I believe the bikes that come with 12.6" shocks have the same stand as your bikes with 12" shocks.
BudTheGrey
2014-2024 Touring Models
Apr 1, 2019 05:59 PM
mtiberio
Sep 9, 2014 09:08 AM
kennygsuperglide
Dec 8, 2012 06:36 PM
Rafkin
Mar 22, 2010 05:45 PM
ettev
Jan 8, 2009 11:24 AM
