cam for tc96?
Old May 20, 2009 | 03:37 PM
jkgraham's Avatar
jkgraham
Default cam for tc96?
i have a fxdc with stage one done and am wondering what is a good or best cam to use in this motor? was told by dealer that se 211 or 255 is too high lift and that i need to stay below a .510 lift. any help would be great. thanks. also will swapping cams kill engine life?
Old May 20, 2009 | 04:41 PM
07bobber's Avatar
07bobber
Andrews cams recommended the 37h cams for my bike but im not sure what type of numbers i would get...
Old May 20, 2009 | 05:11 PM
paul s's Avatar
paul s
Woods TW6-6, Headquarters 0034 or Andrews 37H are all good drop in cams, I went with the 37H for $228.00 Big Boyz has a nice site to compare http://bigboyzheadporting.com/tccams.htm
Old May 20, 2009 | 08:30 PM
CRF's Avatar
CRF
I have no personal experience with it but everything I've read or heard about the Woods TW6-6 has been very good.....If/When I'm in the market for a cam it will be the way I go
Old May 20, 2009 | 10:42 PM
chad peterson's Avatar
chad peterson
Yes...all three of these are great choices, all produce very well!
Old May 21, 2009 | 11:52 AM
07bobber's Avatar
07bobber
What kind of numbers could you expect with these cams? High 80's..maybe 90's? I know it also depends on your setup but i just plan on doing the the stage 1 a/c and keep using my cycle shack slip ons til i can afford a good 2-1 exhaust
Old May 21, 2009 | 12:05 PM
fxdxrider's Avatar
fxdxrider
Default Cams
A SE211 is .510 lift, but a SE255 is a hi-lift version of a 211 to put some mid-range back in. The 211 is considered a revvy, toppy cam.
I like the Andrews 37H in mine, some tuners say "the 37 may not be the right cam but it's never the wrong cam." I take this to mean that it's a good all round cam - it gives more in mid and upper without losing any/much down low. It has good manners and won't cause any problems with durability. The spec on this cam is very similar to a SE204 but with a couple more degrees LSA so it's got more top end punch theoretically.
The R&R525 could be a good option but I've never used one.
Numbers for HP and TQ - dunno but it will feel good.
Old May 21, 2009 | 12:19 PM
FXDFan's Avatar
FXDFan
Would you notice much difference on a stock bike with just stage 1? Would like to add a bit more oomph, just not sure I wanna go the 103" route, I like the idea of reliability and long engine life
Old May 21, 2009 | 12:57 PM
paul s's Avatar
paul s
When my bike cools off I'm going to start pulling it apart for my 37H's, I did a before dyno 70HP@5300/83TQ@3200 when I'm done I'll post the numbers.
Old May 21, 2009 | 01:21 PM
07bobber's Avatar
07bobber
Paul what do you have done to your fatbob so far?
