Oil temp. Wiring
Old May 24, 2009 | 09:47 PM
hallgood's Avatar
hallgood
Thanks guys,
sensor is going into oil pan, drain plug hole.
gauge is going between risers behind handle bars and in front of speedo
Old May 24, 2009 | 09:49 PM
hallgood's Avatar
hallgood
Three wires one ground, one power, and one sensor.
Is there a good power source under consle?
Also 3220x6x2 3/8-1/8 is to big for oil pan drain hole, any ideas?
Old May 24, 2009 | 09:59 PM
mud's Avatar
mud
On my 006 FXDI, I picked up the power and ground off the fuel gauge.........
Old May 29, 2009 | 06:08 PM
hallgood's Avatar
hallgood
Ok, have not wired it yet but, did find out that on 2009 FXDF Fat bobs oil drain plug bushing for a sender is NAPA # 3220x4x2 1/4x1/8...
Old May 30, 2009 | 04:23 AM
04fxdwgi's Avatar
04fxdwgi
Originally Posted by mudpuddle
hallgood, where are you mounting the gauge??
What brand is the gauge??
3 wires??
one.... 12 volt keyed.
two.... ground.
third wire is ????
I always try to pickup power and ground nearby.
Or, under the seat there are several options there.
mud
Hey Mud,
I put my sensor in the oil return line going back to the pan, the rubber one in the cavity between the engine and transmission. Put a "T" fitting in there for the sender and put on new, shorter hose (old one hard as a rock). Best spot to get real engine oil return temp reading. Real tight working in there, but it fit. Cut a small notch in the bottom of the cast aluminum cover to run the wire out and called it done. Gauge (along with oil pressure) mounted on bars. Ran new wire from new inline fuse up from fuse block for the power.
Put the gauges in carbon fiber cups (cost more than the gauges did). So far, so good.
Old Jun 2, 2009 | 03:17 PM
hallgood's Avatar
hallgood
Well, wired the gauge last night, pulled console up and found ignition powered wire to splice into ( thanks MUD) ran wire down clutch cable to oil pan. works great.
Attached Thumbnails Oil temp. Wiring-cimg0322.jpg   Oil temp. Wiring-cimg0324.jpg
Old Jun 2, 2009 | 03:34 PM
Shark46's Avatar
Shark46
I just bought the new oil cap with oil level and temp gauge built in. A little spendy at $139, but I had store credit to eat up so... I like it, but you cannot really check it out while riding. Sometimes at a stoplight I will reach down and push the button and check the temp...seems to be running at 259 when fully warmed up in 95 degree heat, which I think is OK since I run synthetic. I also have the Xied's on it which is supposed to keep it cooler.
Old Jun 4, 2009 | 10:17 PM
mud's Avatar
mud
good deal hall.
Got a picture of the sending unit into the oil pan??
mud
mud's Avatar
mud
Shark, 259F is good, and safe.
mud
Old Jun 7, 2009 | 12:33 PM
hallgood's Avatar
hallgood
Oil pan sending unit...
