Leaking 01 fxdl
Old May 29, 2009 | 10:47 AM
mantodou's Avatar
mantodou
Default Leaking 01 fxdl
hey guys got a small leak from back of primary,,not sure if tranny or engine,neither seems to be low...primary aint leaking,,,does it when sitting static...thinking maybee from starter jackshaft seal on primary,,,do they make a colrong to add to tranny to see if it the leak,,dont really wanna go back into it until i know for sure,,,put the inner primary on 2 years ago. sometimes it drips sometime it dont LOL
Old May 29, 2009 | 12:34 PM
BlacktopBuzzard's Avatar
BlacktopBuzzard
Check the shifter shaft seal...common to leak. Next check main shaft for leak..could be a quad seal or mainshaft seal. They do make dyes for diagnosing where the origin of the leak is. I use Redline Heavy Shockproof (peptobismol in color) in my trans so when shifter shaft seal started to leak it was easy to see. Good Luck
Old May 29, 2009 | 12:38 PM
0lowrider1's Avatar
0lowrider1
any auto parts store ..autozone has that uv dye...works good when you cant find the leak........
Kaycee
Apr 30, 2013 06:49 PM
HarleyReece
EVO
52
Oct 16, 2012 01:53 PM
6speed51
Mar 2, 2012 07:00 AM
wactc88
Sep 8, 2006 10:25 AM
