leak behind primary, suspect main shaft gasket, anyone have tips? 1986 flhtc
Old Jul 6, 2014 | 08:28 PM
watindes's Avatar
watindes
Default leak behind primary, suspect main shaft gasket, anyone have tips? 1986 flhtc
It is pretty much pouring out and I know what it takes to get to it but I am not sure what to order as far as parts, any recommendations for what I should get while I am in there?
Old Jul 6, 2014 | 09:33 PM
Spanners39's Avatar
Spanners39
Take it apart, see what it needs and then order the parts, there is no point trying to second guess these things on a bike of that vintage. The mainshaft has a seal and not a gasket, it could also be the Inner Primary seal or even the gear shift seal....do them while you are in there though.
Old Jul 6, 2014 | 09:47 PM
watindes's Avatar
watindes
I wouldn't imagine the shift shaft seal leaking as bad as it is, it will leak constantly. Made it home and she was empty after 40 miles. Due to the shift seal near the top of the transmission I wouldn't think it would leak like that, am I wrong?
Old Jul 6, 2014 | 11:57 PM
Spanners39's Avatar
Spanners39
You could easily be wrong, if a seal rots and simply falls apart it will leak like a waterfall, if your tranny output seal is shot you may also have a stuffed bearing or the spacer may be scored and has torn up the seal.
Old Jul 7, 2014 | 04:27 AM
bagga's Avatar
bagga
if the splines on the main gear or pulley are worn you will get a serious leak too. if either are worn even a small amount they will have to be replaced. i chased a trans leak for an entire summer and finally figured out the main gear's splines were shot. i replaced it and the leak went away.
Old Jul 7, 2014 | 04:45 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
If oil is pouring out, it is probably a loose pulley nut.
Don`t order any parts until you get it apart.
When you go back together, I suggest using the `94 and later parts (upgraded pulley, spacer, nut, lock, oil seal).
As Bagga said, inspect the splines on the main drive gear (the splined shaft that the pulley mounts on).
Old Jul 7, 2014 | 07:29 AM
watindes's Avatar
watindes
Anything specific I should recognize as wear? Hope its just a seal, I hate dealing with that tapered shaft on the transmission, pulling that clutch basket is nerve racking!
Old Jul 7, 2014 | 04:06 PM
Spanners39's Avatar
Spanners39
Wear is usually grooves or notches in those parts.
Old Jul 13, 2014 | 10:30 AM
JohnnyC's Avatar
JohnnyC
I've had the quad seal between the input and output shaft crap and the tranny oil pours out sitting on the side stand.
Odds are it could be the inner primary bearing race has slipped back allowing the main shaft to very slightly wobble and has taken out the primary seal and possibly the quad seal. There's a solid, single piece inner primary bearing available that some update to.
You won't know for sure until you take off the inner primary.
I pull the clutch basket with a simple "steering wheel" type puller. Tighten it down and give the tighting bolt a tap and it typically pops & slides right off. And don't forget the clutch basket nut is reverse threads.
Old Jul 13, 2014 | 09:30 PM
watindes's Avatar
watindes
The first oil gasket I see is loose in it's housing, I suppose that is the step gasket? Anywho update main shaft, bearing and seals are in order!
Towy4u
May 30, 2020 12:35 PM
philmore81
Jun 29, 2014 04:41 PM
Kaycee
Apr 30, 2013 06:49 PM
Swede405
Oct 31, 2010 10:01 AM
ohshooter
Jun 11, 2010 05:12 PM
