Just got my J&S jack
Old May 14, 2006 | 01:17 PM
Jim Dawson's Avatar
Jim Dawson
Default Just got my J&S jack
My J&S jack arrived Friday morning after only ordering it Monday afternoon. It is expensive ($289 + shipping), but it is everything they say it is. It slips under the Dyna easily and lifts it with much more stability than any jack I've tried. No adaptors required with the Dyna.
I bought the model with the large wheels and it rolls around the garage easily with the bike on it.
I'm very satisfied, fast shipping and well packed. It took about 10 minutes to unpack and set it up.
http://www.jsjacks.com/products.htm
Jim
Old May 14, 2006 | 07:58 PM
superdog48's Avatar
superdog48
Default RE: Just got my J&S jack
I bought a jack like that at Nortern Hydraulics for about $60 to $80 cheaper.
Old May 14, 2006 | 08:43 PM
Naz_Man's Avatar
Naz_Man
That looks like one sweet jack, but it's a little pricey for me!
Old May 15, 2006 | 03:32 AM
Jim Dawson's Avatar
Jim Dawson
ORIGINAL: superdog48
Could you provide a link to that jack? I'd like to see it as my friend also needs a jack
and if they are selling the same thing cheaper I'll send him there.
Old May 26, 2006 | 01:09 AM
AV8tor's Avatar
AV8tor
Hi Jim,
I'm looking for a jack for my 2006 Dyna Wide Glide, and really considering the J&S Jack.
I understand it fits the Dyna without needing the jack blocks that Harley sells. Do you have any photos of your Dyna on the Jack? I interested in how the bike is lifted without needing the Harley blocks? Is it really a easy one person operation? Will the jack work with other bikes too, or do you specifically order it for the Dyna? I'm going to give them a call tomorrow, but thought I'd check with you since you have it and use it first hand...
Sorry for so many questions, but I'm really looking for an easy-to-use & sturdy jack. I actually purchased the yellow Sears jack, and althoug it works... the bike seems to rock & wiggle forward & back on the jack... Not the most comfortable feeling. It's probably fine, but with this much money invested in a bike, I want to make sure my baby is secure when on the jack...
Thanks!
John
Old May 26, 2006 | 01:29 AM
WgSkee's Avatar
WgSkee
Errr.... I've used my yellow sears jack at least a dozen times at full extention and no hold down straps... I can sit on it while it's up with no rockin' or rollin'... If I pulled a wheel I'd use the tie downs... I don't want the impression given that the jack wobbles around cause it dosen't for me... I feels very sturdy... The jack in this post maybe fine I don't know... I hope it works fine for you.. But, my yellow sears works fine... one thing that may make a difference is I use mine on concrete, other surfaces may allow it to wobble...
Old May 26, 2006 | 01:58 AM
AV8tor's Avatar
AV8tor
Hi there,
Sorry, didn't mean to say that the Sears jack was inferior. I dont think my bike is going to come crashing down off the jack, but there is definitely some flex from the front of the bike to the back (jack left to right...) and it is on a flat concrete surface. I definitely wouldn't want to sit on the bike while on the jack. Maybe I just haven't gotten the jack in the right spot on the frame, but the harley jack blocks will only fit in a few spots and I moved them around and experimented as much as I can... Maybe its just that the Wideglide is a longer bike, and the jack width is so small that it is going to flex... Maybe I got a bad one... Maybe I'm a moron...hehe... who knows, but I'm definitely not comfortable with the way its working now.
I'm open to any pointers you might have. The sears jack is definitely priced better, and I would really like for it to work as solidly as yours.
Cheers,
John
Old May 26, 2006 | 02:30 AM
WgSkee's Avatar
WgSkee
AV8tor... No problem... Just didn't want ya to spend big bucks, thought maybe you were doing something wrong... Here is how I do mine.... the same way as wlbowers....
The sears yellow jack is a lower profile than the red one. I have a bad back so I was cautious the first time I did this. I bought the Harley Dyna blocks for one reason only. The slip onto the frame and stay there.
I put the blocks on the frame in the position shown on the sheet.
I get the jack ready to roll under the frame, no extention platforms.
The block on the left rear I pull on the bottom of it till the bottom is pointed at a 45 degree angle away from the Dyna.
I then sit and pull up the kick stand. Then I lean over and push down the block.
Now I grab the handle and roll the jack under.
I give it a couple of pumps till it makes contact.
Once it has I lean over to see if the jack is positioned on the blocks.
Then a few pumps and me and the Dyna go up.
I have really sat on mine while it was up.. setting my bars and stuff like that I weigh 190+ it didn't rock on me believe me I'd be off it in a heartbeat if it did... and I'd be pissed at myself if it fell... Anyways... WELCOME TO THE SITE...
Old May 26, 2006 | 02:36 AM
AV8tor's Avatar
AV8tor
WgSkee,
Thanks for the Welcome and for the info... I just stumbled across this site this week while searching the web... So far, I'm really impressed.. A great site, with great folks... everyone seems so willing to help.
I'll give that method a try and see if it works for me... Maybe I'm putting the darn dyna blocks in the wrong spot or something... I'll double check my positioning of them and give it another try...
Thanks again,
John
Old May 26, 2006 | 02:42 AM
WgSkee's Avatar
WgSkee
This site and the peeps here are great... hell I learn new things everyday here...I hope ya stick around and join the family... CYA..Skee[sm=biker2.gif]
