Project Black FB next.....
Black Cover for the Big Sucker
Also gonna add the HD black floating rotors all around.
Add a 160 front tire
Do a shock mounted license plate frame
1 inch risers with a track style bar??
or pull the front fork legs up and run some clip ons???
If I dont do the clip ons lower the front end...
Lepera Bare Bones Seat with Pad??
Tank Lift or Not??
Also should I leave the headlight or do a Single SJP Headlight with some Lazer LED Bullets on each side like Exile Runs??
Any suggestion guys need some creative help..
The new FB...
you could put a cd on there for now. I'm runnin a 150 up front, it's the biggest you can
fit under the fender. ( notice you are not using one ) something to consider if you put
it back on. don't think clip on's will work with forwards. just don't go ape.
only bit of your bike i don't like is the rear fender.
Tank Lift or Not??
The new FB...
BEAST !!
http://www.biltwellinc.com/Bars.html
I love my Ben-Hur Spikes...LOL
No prob, Yeah I was looking at the clubbam bars but I am looking for more of a track style bar or I might do a dirtbike style alumiunium bar with some narly block style risers.... Not sure...
What do you think about the wheels brotha... I think they came out pretty good but if i pull the gun on some new joints what you think go with a PM styler wheel black and contrast cut in lets say 18's Fr and R or go with blacked out Fat daddy Spokes or even a traditional spoke wheel in 16's????
, I think clip-ons may look killer but you will probably get sick of the position quickly. Plus, they don't make as much sense if you do a lot of 2-up riding. A cool dirt-track style bar for low bucks is the Night Rod Special bar like crooky and a few others use. I think it goes for around $60 from HD. And as much as I like the FXDF I still don't quite like the dual headlights; however they are a key design element of that bike and they work especially well on yours. So I could go either way but don't be in a big hurry to change that.
I'd stick with your current wheels for a while. They're different enough from stock to set your bike apart and will look even better with your proposed black-center floating rotors. (but when you take the plunge, the first place to look is PM/RSD for some contrast cut wheels)
