Brake light sensitivity
Old Jun 7, 2009 | 04:05 PM
BigLowRider's Avatar
BigLowRider
Default Brake light sensitivity
My rear brake pedal does not light the brake light unless I depress the rear brake pedal extremely forcefully - I have to lock up my rear wheel before the brake light engages. The front brake works normal - the brake light lights as soon as I engage the lever.
How can I adjust the sensitivity of my rear brake pedal so that it lights the brake light with much less pressure applied to the pedal?
2003 Low Rider with running lights.
Thanks, BigLow
Old Jun 7, 2009 | 07:15 PM
jsbridgew's Avatar
jsbridgew
mine does the same thing
Old Jun 7, 2009 | 07:54 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
The rear brake switch is activated by the brake fluid being compressed by the pedal movement, your switch could going away. The pedal adjustment is done by turning in the brake pedal rod at the master cylinder.
Old Jun 7, 2009 | 07:59 PM
chengdave2003's Avatar
chengdave2003
The rear brake switch needs replacing....
Dave
Old Jun 7, 2009 | 08:35 PM
06dynablack's Avatar
06dynablack
you could also try cleaning the contacts first
Old Jun 7, 2009 | 09:45 PM
JaronB's Avatar
JaronB
Mine does too and I only have 2700 miles on my bike. It doesn't lock up though. Either way you're suppose to use both brakes and the front is usually the first and last brake I touch, so I don't worry about it.
Old Jun 7, 2009 | 10:25 PM
archergodwin's Avatar
archergodwin
May want to double check the fluid level in your rear master cylinder.
Old Jun 8, 2009 | 10:20 AM
chengdave2003
If you have to stand on the brake pedal to get it to work and it works each time you do it, you have a bad switch (been there, done that). If it were dirty or loose contacts it wouldn't matter how hard you stepped on the pedal, and it doesn' t matter how new or how old the switch is, it can still be bad.
No argument intended, just sure I'm right.
Dave
Old Jun 8, 2009 | 10:58 AM
r00k's Avatar
r00k
Dave
I would agree with you
Old Jun 24, 2009 | 06:36 PM
BigLowRider
I installed a new stoplamp switch and everything is now a-okay.
Thanks for your help!
BigLow
ECK Road King Classic
Wheels/Tires
Nov 12, 2013 07:51 AM
ceekncabin1
May 4, 2013 09:52 PM
dagored11
Feb 4, 2010 09:55 PM
67bullitt
Jan 31, 2010 07:40 PM
dan boudreau
Electrical/Lighting/Alarm
Aug 24, 2008 07:44 PM
