Proper way to down shift?
Old Jun 8, 2009 | 07:26 PM
  #41
Gwjvw's Avatar
Gwjvw
Originally Posted by Gary7
I've never understood the concept of downshifting when coming to a stop. I've never done it with any manual tranny cars I've owned and I've never done it on my bikes. It's the least efficient way to slow the bike down, causes unnecessary wear on the clutch and primary chain, and because you can't modulate the stopping force you are applying to the rear wheel, you always risk a lock up--especially on anything other than clean dry pavement.
Slowing and stopping are what the brakes are for, not the clutch and the engine. Just my 2 cents.
I really disagree with that opinion!
Also one reason why its nice is it would suck coming out of 6 and clicking all the way down to 1st,(could be more dangerous if your not counting your down clicks and let the clutch go at a low gear and a high speed thinking you werent that low,,major wheel lock up) ,,in a car i would understand,because its easy to go from 5th to N and so fourth, on a bike its just part of the gears and rpm range going down plus,the big plus while your doing it,it really helps you slow down alot! As for locking up the rear wheel,i would say maybe more practice or maybe even a riding school,because thats hard to do,unless your a super new rider! (not referring to you but people that have this problem!)
Just my 2 cents.
Old Jun 8, 2009 | 07:50 PM
  #42
08FXDC's Avatar
08FXDC
I use downshifting as way of braking to slow down... never had any motor, tranny or clutch issues...
Old Jun 8, 2009 | 08:12 PM
  #43
TO34's Avatar
TO34
Talking Thanks :)
Originally Posted by Phrogman
You guys are talking about two different things, but using one term and it's confusing me and probably others.
1) Downshifting= Shifting to a lower gear as speed is decreased to maintain proper gear to speed ratios for immediate response to any situation.
2) Compression braking= Utilizing the compression of the motor while slowing to assist in reducing the speed of a vehicle, downshifting to maximize the effect and to avoid stalling the motor.
In short, I always downshift when stopping. I sometimes utilize compression braking in conjunction with my front and rear brake to stop the bike. It depends on how fast I want to slow my speed.
Just to repeat good post.. It all depends on how fast you are going & how fast you want to stop.
  #44
archergodwin's Avatar
archergodwin
For you guys claiming undue wear on clutches and engine because of downshifting and using engine braking, you better stop accelerating and shifting up as well. Better just let your bike sit in the garage and not get any wear at all..... I've driven every kind of vehicle with manual trannys and clutches from small bikes to 18 wheelers (professionally).
I used to shift the truck with no clutch usage at all.... upshifting and downshifting.
When getting ready to downshift, I blip the throttle to raise engine rpm at the same time pulling the clutch and downshifting. When you release the clutch, the engine rpm should be at rpm it should be, for the speed you are going and the gear you are in. It's no big damn deal. I've never 'chirped' the tire or broke it loose while downshifting... unless it was on purpose.
So if you still disagree, fine.... but explain to me in detail exactly what "extra" wear the engine and clutch is going through while downshifting/engine braking, that is worse than you accelerating away from a stop?
Old Jun 8, 2009 | 08:20 PM
  #45
Gary7's Avatar
Gary7
Originally Posted by archergodwin
For you guys claiming undue wear on clutches and engine because of downshifting and using engine braking, you better stop accelerating and shifting up as well. ... So if you still disagree, fine.... but explain to me in detail exactly what "extra" wear the engine and clutch is going through while downshifting/engine braking, that is worse than you accelerating away from a stop?
Assuming you engine brake 1 time for ever 1 time you accelerate, the added wear is 100%. Also, engine braking can put more torque to the clutch than the engine can during acceleration.
Old Jun 8, 2009 | 08:30 PM
  #46
Dawg Rider's Avatar
Dawg Rider
Anybody that can't downshift without lockup should stay off two wheels IMO. And I think some of y'all overstate the wear compression braking causes an engine, at least if it's done right. On twisties, the strong engine braking is one of the big pluses of riding a Harley IYAM. Not using it while aggressively riding mountain roads is a prescription for overheated/fading brakes, too. On flat roads, I don't think it's a big deal either way.
As far as efficiency goes, I agree that the brake lever (and pedal to a lesser degree) is the ticket. In an emergency stop, the last thing on mind is engine braking.
Old Jun 8, 2009 | 09:14 PM
  #47
archergodwin
In all my years of driving manual trannys Gary, I've never had to replace a clutch. I know where your coming from, but it's just not that much to worry about.
If the clutch is not slipping, where is the wear?
Just for argument sake here, what do you do on an extended downhill stretch?
Old Jun 8, 2009 | 09:36 PM
  #48
greenyetti's Avatar
greenyetti
[quote=Just for argument sake here, what do you do on an extended downhill stretch?[/quote]
after reading 5 pages of this thread I can safely say I think argument's sake has sufficiently been established.................... but please, do proceed
also,
+1 more here
Old Jun 8, 2009 | 09:47 PM
  #49
Glydiator's Avatar
Glydiator
Lol....well the question was "whats the proper way to down shift?"
Can one possibly glean a sure answer from these posts..... not likely. But thats the good thing about these forums. Lot's of good advice and opinions for you to ponder, and learn from.
From what anyone could gather, it depends on road conditions, your preference, your technical knowledge of the inner workings of a combustible engine/transmission and the proper gear to speed ratios, how much time you have, your experience level, and whether or not you give a crap about the way you stop as long as you don't smash into the object in front of you....
One of my favorite ways to stop is to jam the rear brake...slide about half sideways up to the folks at the corner and as soon as that blue rubber smoke blows past my face I turn with a serious look on my face and say... "****** A"
Old Jun 8, 2009 | 09:58 PM
  #50
bberck's Avatar
bberck
I always down shift to be in proper gear and I use engine braking also. As long as your not jamming it into way to low of a gear slight engine braking isnt going to hurt anything.
Personally I feel in better control with the clutch not engaged coming to a stop. I pull it to downshift and when I have to completely stop. There has been many of times I have had to hit the gas hard for some reason and dont wont to worry if I am in the right gear. To me its one of the many small things you do on a bike to minimize risk.
If that causes extra engine/clutch wear I am fine with it.
On my quads I used engine braking hard when running in the woods and never wore out a clutch.
