changing clutch cable
Old Jun 9, 2009 | 08:33 PM
MyBeerBelly's Avatar
MyBeerBelly
Default changing clutch cable
Hi all
the service manual says I have to drain the trans fluid and i think remove my pipes...is this true or is there an easier way on a dyna?
J
Old Jun 9, 2009 | 08:39 PM
cdouthitt's Avatar
cdouthitt
I just did mine last weekend...depending on your pipes, you may not need to remove them...I had access to all the bolts with mine. You'll need to drain the trans fluid...
Oh, and have fun with the giant snap ring under the cover...my snap ring plier tips weren't able to compress the ring...I had to resort to a pair of needle nose pliers that had small tips.
Grind's Avatar
Grind
I did it once without draining it by rolling the bike onto two 2x8s, with a rope from the rafters for support. Lost a few drops. If/when I have to change the cable again, I'll drain the trans. Much less hassle and alot less time.
Old Jun 9, 2009 | 08:48 PM
MyBeerBelly
my apes change is turning into a headache....took my forks to dealer today to press seals in and they scratched my lower...went to pick up my cables from another dealer and the forgot to order the idle cable...and its on backorder until next week...and next week is bike week up here....and to add i snapped the bolt in the lower tree that holds fork tonight....ahhh i feel better
J
Old Jun 9, 2009 | 08:49 PM
SC-Longhair's Avatar
SC-Longhair
Buy a channel lock heavy duty retaining ring plier. You'll need it.
Old Jun 10, 2009 | 12:35 PM
fixxr's Avatar
fixxr
You can spin the snapring around alittle to get at it a little better,it makes life EZ'r
RaceFace
Jan 31, 2013 01:06 PM
Trippster
Feb 3, 2010 06:42 PM
justinmark79
May 17, 2009 08:02 AM
~Bobtail~
Apr 29, 2007 11:38 AM
ultravista
Nov 5, 2005 11:26 PM
