New Clutch Cable
Old Feb 3, 2010 | 11:19 AM
Trippster's Avatar
Trippster
Default New Clutch Cable
I'm changing my clutch cable today and the manual says to drain tranny fluid. Is it really nessecary to drain the fluid since the bottom of the cover is about 6 inches above the bottom of the tranny. I know it only holds 1 quart but I just can't imagine the level being that high. I just changed it about 1000 miles ago and I don't want to have to do it again if I don't have to.
Old Feb 3, 2010 | 11:31 AM
PistonPuller's Avatar
PistonPuller
You can put each tire on a 2x4 or some type of block. then when the bike is on its jiffy stand it will lean over far enough that you shouldn't need to drain the oil. Just make sure it's not leaning too far over
Old Feb 3, 2010 | 12:16 PM
J-RoX's Avatar
J-RoX
+1 i used 2x6's, i had them and i felt safer. you will lose a drip or two.
why the change?
Old Feb 3, 2010 | 12:25 PM
rounder's Avatar
rounder
yup bike on 2x6 will lean it over far enough. Or you could just get a o ring for the drain plug, drain oil into a clean container, change cable, and pour fluid back in. I did that once.
Old Feb 3, 2010 | 04:37 PM
Trippster's Avatar
Trippster
I used the 2x6 worked great. Onlt lost a couple drips. Thanks for the help.
Old Feb 3, 2010 | 06:42 PM
FUQUA's Avatar
FUQUA
I just drain mine...
tigercreek
Aug 23, 2015 09:51 AM
el_james
Jan 25, 2014 06:11 PM
LeFat1
Jul 29, 2013 04:06 PM
rrsjs5
Sep 24, 2008 03:03 PM
RDKNGLVR
May 27, 2008 05:45 AM
