StreetBob
Old May 18, 2006 | 01:44 AM
StreetSalvation's Avatar
StreetSalvation
Default StreetBob
I pick up a bob resently. I found this here forums and have spent countless hours on here. The question i have is out there but i have not read a concret answer. Here it is: I am putting screaming eagle pipes 80419-06 with the highflow filter 29440-99L. I asked about the PC111 at the dealer and they said that was junk and said just the download works. I had asked my family mech about it, who also owns a couple harleys, and he says he trusts the dealer. I am hearing about the SERTs and other things. I want to know what will make my bike run the best and i am on a budget. I am not worried on becoming the fastest bike or the loudest just mech sound. The question is What do i go with the slip-ons and airfilter?
Old May 18, 2006 | 02:09 AM
Stucarius's Avatar
Stucarius
Default RE: StreetBob
Honestly there are a million different opinions. For just something straight up and if you are doing teh high flow air filter (which you should do) the DFO is a great cheap solution. For a better performance solution but costly try the terminal Velocity setup or the SERT. I have recently become a little less enthused with the PC3 for the o6 EFI setup.
Consider not getting slip ons. Get some actual pipes like Bassani which will increase your performance and cost the same. Slip ons are not a true stage 1 upgrade in terms of improving teh performance of your bike. If you are spending the money you might as well get the performance for it. Bassani Pro Streets will cost you around $425.00.
Hope that helps some.
Old May 18, 2006 | 07:45 AM
irlm1's Avatar
irlm1
Hi StreetSalvation
i#m in a similar boat to you, on a budget of sorts, and want better sound,looks etc not top mph, and have been on here gathering info for a while.
From what I gather you have a few options, ...most imortant 1... dont blindly trust the dealer. There probably great but Each has a completly different opinion....based on god knows what....maybe what theyre familiar with, what they have in stock, what they can get best markup on, what their guys are best at fitting etc. anyway...some options i've considered based on info gained here:
HD download - cheapest option. dealer add news map to your injection system. A lotta guys get the wrong map by accident or dealer confusion. Check carefully. If you get the wrong 1, or next year you buy new pipes, then you start all over again. no flexibility to tweak.
TFI (also called DFO, Techclusion) - a black add on box, that you can fit yourslef, and tweak a few settings with a couple of buttons on the box. Good video on this forum showing an install.
PowerCommader - A little more pricey. Another add on black box. can tweak a little more. You may even be able to contact the manuf. to get alternative downloads if you change e.g. pipes later.
SERT (Scr. eagle race tuner) - another little bit more expensive, and more involved, but from what i understand...ultimate control???....even more so than the old days with your screwdriver and a bag of jets and needles for ur carb.
info on all of them here somewhere. check the tech areas also.
goodluck!!!
Old May 18, 2006 | 09:35 AM
StreetSalvation
Thanks to both ya, I was looking at different pipes but i really like the the whole tappered look. I fond a pair of v&h that did the tapper but it was not for a 06 with the sensor. How much is the SERT and were can i get it?
Old May 18, 2006 | 10:57 AM
SDMF's Avatar
SDMF
StreetSalvation...You can get the SERT (Screaming Eagle Race Tuner) at your local Harley stealership. They run around $425
Old May 18, 2006 | 04:58 PM
jw5150's Avatar
jw5150
SERT www.zanottimotor.com Order online for $357 plus shipping. If in PA then add sales tax. Just got mine from them. I am in PA. I had it in 1 day. Good luck.
Old May 18, 2006 | 08:23 PM
StreetSalvation
Whats the part number for the sert?
Old May 18, 2006 | 08:29 PM
DyNaBoB's Avatar
DyNaBoB
i have the pc111 and its the best thing i did to my bob the dealer just pushes their product the pc111 has alot of tuning plus a free xcelarator pump for more horsepower
Old May 18, 2006 | 08:47 PM
hd_sob's Avatar
hd_sob
I have the 'all H-D' stage-1 on my Bob:
SEII slash down slip-ons
SE a/c filter kit
HD download for above
My sled sounds and runs great. Eventually I might get V&H Big Radius, but will wait til I tear up what I got first...
Old May 18, 2006 | 08:56 PM
mcurry5's Avatar
mcurry5
my set up is a pretty typical one for the dynas
V&H Big Radius
PCIII
K&N AC
