vibration on 07 dyna low
Old Jun 24, 2009 | 03:31 AM
magforce's Avatar
magforce
Default vibration on 07 dyna low
starting out from a stop today had a very bad vibration, so bad it shook the begs and hole bottom of bike then out of no were it stop. it felt like the hole bottom of the engine was going to fall out. any ideas guys
Old Jun 24, 2009 | 05:04 AM
CRZYLGZZ's Avatar
CRZYLGZZ
Check for slack clutch cable and components. And your throttle assembly. Sounds like you were stalling. Maybe you're due for a check up.
Old Jun 24, 2009 | 06:13 AM
YourOldDog's Avatar
YourOldDog
Make sure your belt drive is properly adjusted. I could see that causing quite a rumble
Old Jun 24, 2009 | 06:50 AM
ColdCase's Avatar
ColdCase
A misfire or timing problem (intermittent) often shows up as a vibration. Perhaps you got some water in a sensor of bad gas? Only happened once?
Old Jun 24, 2009 | 01:47 PM
magforce's Avatar
magforce
just once then it stop, after about 5 miles or so. bike only has about 6800 miles on it.
br549A1
EVO
17
Apr 8, 2014 08:10 PM
sbcvulcan
Jul 9, 2013 08:05 PM
magforce
Jun 23, 2009 05:48 PM
Grayzone
Oct 16, 2008 07:40 PM
Dog Folks
May 29, 2005 12:42 AM
