Got my heads....
Old Jun 26, 2009 | 11:29 PM
Funkhousert's Avatar
Funkhousert
Originally Posted by thedonthere
No. But, this winter when I tear it down again and do the 95" and different cams I will. Did it now because it was easy to do now. No more head work needed this winter. After this winters mods I will be right at 10:1
Wow are you related o Tweakin........LMAO
Ummm its early but I wanna call dibbs on the Andrews 37h......
Old Jun 26, 2009 | 11:49 PM
chad peterson's Avatar
chad peterson
The Woods TW-7H or TW-8-6 and Weisco pistons. F**k dude I'm hooked!
LOL! Happens real easy don't it. I got a feeling you'll like them tw-8-6 cams better...the 7's are great, but the 8's will benefit better from your headwork & higher compression (carry out a little more) while still makin a solid botom. They are very simillar to my t-man 590's.
Old Jun 27, 2009 | 02:39 AM
spiritwarrior's Avatar
spiritwarrior
Looks nice, I used to play with Volkswagens years ago. A little porting, new valves, performance cam, could get you 15-25 more HP easily.
When my warranty runs out may play around with the bike a little. Thinking a higher volume oil pump and rigging a Jagg cooler with a thermostatic controlled fan. South Korea can get hot coupled with stop and go traffic, it's and oil killer. I change it every other month in the hot season.
Old Jun 27, 2009 | 08:04 AM
883 IRON's Avatar
883 IRON
Hey Don,
Do you have a pic of the intake and exhaust port on that head? I saw Tiges and it really gets me thinkin (dangerous for me).
Steve
Old Jun 27, 2009 | 08:52 AM
formike56's Avatar
formike56
You have the bug.... Wait till you twist the throttle with that build.....
Old Jun 27, 2009 | 08:53 AM
redrubicon2004's Avatar
redrubicon2004
Why not keep the 37's and save a few bucks? They would work really good in the 95" build. Very nice all around cam! https://www.hdforums.com/forum/dyna-...o-results.html
Old Jun 27, 2009 | 09:15 AM
redrubicon2004
Originally Posted by paul s
I go back and forth on going 103ci while I pull my heads or staying 96ci, I can't make up my mind. I don't want my cylinder walls too thin or too high compression with this FL. heat. I'm shooting for mid 9's and it looks like that can be had like you just did. What pipe did you go with?
That wouldnt be a problem at all. 96"=3.75" bore, 103"=3.875", and lots of guys now boring them out to 3.937" for a 107"! Alot of the big builders are going out that far, if they had heat issues they would have stopped by now. 103" would be fine! I wish I had bored out to the 3.937" and had a 98" vs a 95". Next year I am going to try and go with a 107" all bore on my 88" crank. I would be using Axtell cylinders and boring the cases though.
Old Jun 27, 2009 | 10:32 AM
thedonthere's Avatar
thedonthere
Originally Posted by 883 IRON
Hey Don,
Steve
Here Steve, photography is not my best atribute !
Intake
Exhaust
The majority of the porting takes place on the intake side. HD restricts the intake port possibly for EPA reasons. The exhaust port is fairly large to begin with and it just gets cleaned up. It's not a big size port you want, what you want is the best velocity. Bigger is not always better in this case. Don
Old Jun 27, 2009 | 01:42 PM
ackman1968's Avatar
ackman1968
Damnit I want some heads too!!! Who did the work for you Don? I think I saw it in another thread but I'm too lazy to go lookin.
Old Jun 27, 2009 | 01:52 PM
TOMMAY's Avatar
TOMMAY
I'm sure you already know this,but I read an article on one of the performance webs sites which showed how the factory header gaskets sometimes compressed into the exhaust port negating some of the flow that you spent so much money trying to achieve. It showed an aftermarket gasket that was a little trickier to install but would prevent the gasket from bulging into exhaust flow. I wish I could find the link,know I saved it but can't find it now.
Good Luck
Tom
