Rush mod./cranking
Old Aug 10, 2009 | 08:09 AM
checkers's Avatar
checkers
muffler install should not effect starting as described. make sure when you turn on ignition you wait a moment and listen for fuel pump to build presure and shut off. you will hear it stop and then crank it over, shud "pop" right off
Old Aug 10, 2009 | 09:32 AM
MYKSHD's Avatar
MYKSHD
Default Rush/mod
I put the Rush 1.75s slipons on and a PC-V on my 2008 Fatbob. I noticed right away that it had to crank a couple of rpms more than stock if you let the light come on. If you turn on the key and crank it right up it is better to start. Mike
Old Aug 10, 2009 | 11:54 AM
dyna07custom's Avatar
dyna07custom
Still should not crank to the point of draining the battery Like others have said could you have hit something, are mufflers tight, are there any codes showing?
bdeuce
Jul 10, 2014 10:27 AM
vowens226
General Topics/Tech Tips
Jan 10, 2011 01:20 AM
dedjr67
"The Florida Crew"
Feb 21, 2010 10:30 PM
hommes
Sep 16, 2009 05:13 PM
drichards
Exhaust System Topics
Aug 21, 2006 08:38 PM
