Fatbob Tri bar light.
2. Any hints on how to make a clean wire harness to splice from old to new - I am very **** about little details
3. How did you past a big picture of your bike into the main body
I really like your horn relocate - it is small details that really count NICE JOB
Rschmidy
Seattle
Rschmidy
Seattle
2 ) i just cut the old harness and spliced in some pieces of wire , using heat shrink tubing and black wire loom . stuffed the harness up between the tank and the frame with the other wires .
3 ) i think it was in the signature part of the forum .
1. shear the license plate (or use metal cutting blade on table) right above top mounting holes leave as little margin as possible between hole and sheared edge - you do not have to do this and you will only loose about 3/4 inch of "hiding" - but it is all in the details
2. The light kit is two piece - one light and one license bracket -
3. take license bracket and push recently cut license to top of bracket and match drill two holes to screw license to bracket
4. cut off little center tab of bracket - you are only going to use top two holes to mount license
5. purchase smoked cover from http://www.autobarn.net/smoke-tuf-shield.html
6. cut smoked cover with any radial or table saw right thru the bottom of top two holes - you are only going to use bottom two holes to mount cover right to license plate
7. use #10 - 32 flat head screws to mount cut license to new matched drilled holes in license bracket - use small length of fuel tube to space license out tangential to tire - jsut play with this a bit
8. attach smoked shield to license with two screws only in bottom two holes
that is it - really it is one trip to hardware store after you cut everything
good luck lemme know if you get stuck
Rick
