'11 Street Bob tail light
Old Jun 9, 2011 | 01:04 AM
JojotheDogFaceBoy's Avatar
JojotheDogFaceBoy
Default '11 Street Bob tail light
Got sick of looking at the hideous taillight on my bike today. Decided to clean it up a bit. I used existing hardware and some odds 'n ends I had laying around the garage. Not quite finished yet, but here's a few pics. I need to go to the hardware store tomorrow for some nuts and bolts, and for something to secure the wiring under the fender.
I plan on adding a license plate light at some point, maybe a small strip of white LED's or somthing.
Let me know what you think?
Attached Thumbnails '11 Street Bob tail light-bobtail1.jpg   '11 Street Bob tail light-bobtail2.jpg
Old Jun 9, 2011 | 08:30 AM
Dustdevil21's Avatar
Dustdevil21
I am with you on the tail light, ugly thing. And there aren't many replacement options either!
What are you running for a tail light? Your turns integrated with the tail light?
Your solution does clean up the rear fender better.
Old Jun 9, 2011 | 09:47 AM
DSnoopy's Avatar
DSnoopy
Yep, I painted mine to tolerate it until I get my new fender and lights on.
Good ideas.
Old Jun 9, 2011 | 10:06 AM
craigffb's Avatar
craigffb
Just my but I think the plate on there looks worse then the tail light. I cut the tab off the light and moved the plate to the swing arm. Only thing I had to buy was a lighted plate frame. Used the front belt guard braket and OE plate hanger to make the side mount.
Old Jun 9, 2011 | 11:14 AM
JojotheDogFaceBoy
My turn signals do everything from the factory on my year Bob. I think it's something different. I would eventually like to replace the rear fender with one that doesn't have any holes or the stupid cleft chin at the bottom.
Old Jun 9, 2011 | 11:16 AM
JojotheDogFaceBoy
I hear ya, but there aren't too many other options. I just don't like the third light and I cannot mount my plate vertically on the side. CA vehicle code changed and you cannot mount your plate vertically anymore. I could probably get away with it, but being in my line of work, I like to try to set an example. Plus, my boss would probably compel me to make it compliant. I already get doo doo for my loud pipe...
Old Jun 9, 2011 | 11:22 AM
JojotheDogFaceBoy
Looks like they make LED license plate bolts. That might be a winner there...
Old Jun 9, 2011 | 12:55 PM
craigffb's Avatar
craigffb
You could still mount it horizontally using the same method I did. I just thought it looked better vertically. I don't think it would stick out to much more. The reason I used a frame instead of the LED plate bolts is there was less wire to mess with.
Old Jun 9, 2011 | 11:16 PM
JojotheDogFaceBoy
Not a fan of the horizontal mount off to one side. I really wanted to get a vertical side mount but no dice. Guess it's just my OCD wanting things to be somewhat symmetrical...
Old Jun 15, 2011 | 07:12 AM
BoeingMan's Avatar
BoeingMan
Thinking bout getting rid of the duck tail brake light myself. Something on my to do list for sure.
