bike runs like garbage
Old May 21, 2006 | 04:32 PM
duffy702's Avatar
duffy702
Default bike runs like garbage
I had pyhthon staggered pipes with the se air cleaner and the stage 1 download. bike ran good for a couple of weeks now all of the sudden its running real hot and justt doesnt sound right anyone else out there have any problems like this. at this point i'm thinking about putting a power commander in it and just saying screw the dealer and the warranty. any ideas would help
Old May 21, 2006 | 04:44 PM
Naz_Man's Avatar
Naz_Man
Default RE: bike runs like garbage
ORIGINAL: duffy702
The power commander voids your warranty?
Old May 21, 2006 | 05:05 PM
fl_799's Avatar
fl_799
Was the weather a bit cooler a couple weeks ago? With Python staggered pipes, that stage one map is WAY off the mark, not even close. You have to do some sort of fuel enrichner to tune 'er up no question about it. Probably the easiest is having the Steeler put on the Race Fueler which, being a HD product, has its own set of 'advantages'.
Old May 21, 2006 | 06:48 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
I would think seriously about the SERT.
Old May 21, 2006 | 08:37 PM
truenorth's Avatar
truenorth
Try installing a Techlusion DFO, it's a cinch to install, no computer downloads to worry about, easy to change the EFI mapping and it only cost about $200 from Eastern Cycles. I love mine, it makes my 06 Street Bob run real smooth, no decel pops. I have SE II's, K&N & Techlusion DFO.
Truenorth.
Old May 21, 2006 | 08:53 PM
05LowRider's Avatar
05LowRider
Just a thought here but have you re-checked the pipes to make sure they're still tight at the manifold? You said you just had new pipes put on and I wonder if they need to be re-torqued. I had one come really loose on me and it quit firing on that cylinder. Might want to check it out.
Good luck.
Old May 21, 2006 | 10:02 PM
duffy702's Avatar
duffy702
weather was alot cooler a few weeks ago, checked all nuts everthings tight no exhaust leaks.
Old May 21, 2006 | 11:41 PM
mcurry5's Avatar
mcurry5
Power Commander. Paid 279.00 bike is running better than ever. Hasnt been real hot outside yet though. I have the V&H Big radius.
Old May 22, 2006 | 12:40 AM
duffy702's Avatar
duffy702
did you put in the power commander yourself? how much of a pain in the *** was it to do the remap?
Old May 22, 2006 | 03:51 AM
mcurry5's Avatar
mcurry5
i put it in myself, took 15 min. they have most maps on there site. no tuning necessary get bike at about 90-95 % optimum performance.
