96 DYNA VIBRATION
Old May 22, 2006 | 12:08 AM
bojangles's Avatar
bojangles
Stage I
Default 96 DYNA VIBRATION
[>:]I HAVE A 96 DYNA FXD 11000 ORG. MLS. ABOOUT 2000 MLS AGO DEVELOPED A VIBRATION IN REAR OF BIKE,AFTER WARM UP,BETWEEN 2200 AND 33OO RPM....FELT LIKE FLAT SPOT ON ORIGINAL REAR TIRE,LOCAL H-D SHOP INSTALLED NEW TIRE,BALANCED PERFECT,ADJ. BELT TO SPEC.....STILL SAME PROBLEM...SUGGESTED REPLACE FRNT&REAR MOUNTS STILL SAME PROB....MAYBE TRY SELF ADJUST. PRI.CHAIN KIT...DID THAT ..NO CHANGE...TOOK TO INDEPENDENT SHOP WITH DYNO...CAN ACTUALLY SEE AND FEEL VIBRATION IN REAR-FENDER,WHEN WARMED -UP AT 2200-3300 RPM,MOST NOTICEABLE IN 4TH&5th GEAR....HE SAID NEVER SAW THIS TYPE OF SITUATION...MAYBE A TRANS OR HUB BEARING....IGNITION,CARB AND TIMING ALL 100%....BEFORE I TEAR INTO UNKNOWN ANY IDEAS ????????DAC
Old May 22, 2006 | 05:34 AM
wlbowers's Avatar
wlbowers
Default RE: 96 DYNA VIBRATION
Take the chain/belt off and run it. See if it is still there.
Old May 22, 2006 | 11:56 AM
SDMF's Avatar
SDMF
bojangles...Do you have laced wheels? If not, no need to read on. I read another thread either on this forum or another, but this other guy was having the same problem you are and he found that he had a couple of loose spokes. He just retorqued them and the vibration went away.
Old May 22, 2006 | 04:43 PM
wlbowers's Avatar
wlbowers
Damn SDMF! You beat me to it. I read the same post last night about 2am.
rogersachs
Apr 18, 2019 05:44 PM
McMurphy
Aug 3, 2013 04:45 PM
texasridr
EVO
Nov 6, 2011 05:10 AM
rickshog
Sep 5, 2006 03:55 PM
gibbyfxstc
Jun 30, 2005 04:17 PM
