Forward Controls ?
Old Jul 12, 2009 | 07:01 AM
Nuge's Avatar
Nuge
Default Forward Controls ?
I am going to put on Forward Controls on my 08 super glide.
I don't know if i should go with the HD kit or an aftermarket kit.
Are some kits better then others? Has any one used a aftermarket kit?
What are the pros and cons?
Thanks nuge
Old Jul 12, 2009 | 07:33 AM
Delmarksman's Avatar
Delmarksman
Do a search on it, you will find a ton of posts covering everything you asked about.
There are as many opinions as there are folks using the different setups.
I myself, and many others have used the '05 HD kit with a seperate/longer connecting rod, with great results.
This allows you to leave the shifter shaft in place if you want,
or put differently you won't have to seperate the primary cases.
I left my mid pegs on for a different place to put my feet, if I wanted to.
That being said I don't like having my feet away from the controls.
Old Jul 12, 2009 | 07:49 AM
Mr. Wizard's Avatar
Mr. Wizard
The Kuryakyn kit is much better (IMO) and cheaper than the HD kit. I got mine from Eastern Performance on ebay... saved lots of cash over the online retail.
If you're taller than a 33" inseam then get the 3" extension kit.
Old Jul 12, 2009 | 08:13 AM
YellowHawk's Avatar
YellowHawk
Unfortunately, unless you find someone that has used several different ones, you can't get a very good report of which one is best and why. All you get is opinions on whatever one somebody has. Like me...I have the HD forwards. I like them fine but I haven't tried any other brand.
Old Jul 12, 2009 | 08:22 AM
Mr. Wizard's Avatar
Mr. Wizard
Clarification... I ripped the HD forward controls off and put on Kuryakyn.
OK, you got me, I really didn't but I did do a side by side comparison before purchasing my own for an 07 Low. Rode both bikes... The Kuryakyn seemed to be of better material, better chroming and shifted smoother. As I mentioned above... (IMO) in my opinion.
This is why God made black and white.. just different choices for different folks cause not everyone has the same taste.
Cheers
Dudepants
Feb 14, 2017 08:10 AM
13bob
Apr 23, 2015 05:42 PM
Narco101
Jul 9, 2009 01:12 PM
Street Rob
May 7, 2006 06:12 AM
98fxd
Aug 5, 2005 05:30 PM
