Head winds Headlight Help!!!!
Old Jul 18, 2009 | 08:45 PM
Narco101's Avatar
Narco101
Default Head winds Headlight Help!!!!
I just mounted a headwinds head light and I am not sure if the mounting block on the bottom is faced the correct way. Can anyone post pictures to show me the correct way.
Thanks
Nick
Old Jul 18, 2009 | 08:50 PM
thedonthere's Avatar
thedonthere
You can mount it either way. Mine is turned 180 from stock and is 5/8" shorter to center my light better between my trees
Old Jul 18, 2009 | 10:00 PM
thedonthere
Nick, Ive never seen one mounted like that, Thats funky lookin. Here's mine
How did you do that?
Old Jul 18, 2009 | 10:22 PM
Narco101's Avatar
Narco101
I tried the stock mounting block but it is to short and causes the shell to hit the neck. This block is about 1/2 inch to long.
Old Jul 18, 2009 | 11:04 PM
Baeseman1's Avatar
Baeseman1
Narco - I had to move my new headlight quite a bit forward for clearance issues. I have my mounting block laying down like you have - but mine is like 2.5" long. How far forward do you need to move it?
Old Jul 19, 2009 | 08:48 AM
Narco101's Avatar
Narco101
I would actually like to move it back 1/2 inch. Does anyone know where I can get a different block?
Old Jul 19, 2009 | 08:59 AM
kk6pg's Avatar
kk6pg
I used the 1" vertical mount on mine. If I would have used the offset, the headlight would have been hanging out there, in line with the front tire.
You can get just about any type of mount directly from Headwinds. Theyre pricey, but you get what you pay for. And if you get the chance to visit their place in Monrovia, you'll get a guided tour through the whole facility. Definitely a class act.
Old Jul 19, 2009 | 10:02 AM
Baeseman1's Avatar
Baeseman1
Not to sound stupid - but a 1/2" back from what length???
It probably won't work, but you can have this is ya want it.
Otherwise, here's a link to the Headwinds forward mounting blocks
http://www.headwinds.com/mm5/merchan...ode=0101020102
Old Jul 20, 2009 | 01:14 PM
Narco101's Avatar
Narco101
The block needs to be a 1/2 inch shorter. Then it won't stick out as far. Is there an easy way to cut it down to size?
Old Jul 20, 2009 | 01:30 PM
JRK5892's Avatar
JRK5892
i took my stock one and cut it down to drop my lamp a bit more into the trees
Free Spirit
Electrical/Lighting/Alarm
Feb 22, 2012 09:57 AM
dynamiamiflo
Aug 22, 2011 09:03 AM
ironhide_uk
Sep 14, 2010 03:39 PM
ironfist_001
Mar 30, 2010 10:39 AM
buellrider76
Feb 14, 2009 12:30 PM
