belt to chain conversion
Old Dec 30, 2010 | 07:07 PM
JRK5892's Avatar
JRK5892
not just more power it transfers power better to the tire... one of the guys that races super cross broke it down one night to me after a case of beer, ill be honest i stopped listening after a while but he was very detailed and i have yet to find any info that says he was wrong...
Old Dec 30, 2010 | 07:18 PM
dtwade's Avatar
dtwade
Actually, there is a belt repair kit available. The belt is spliced together. it's temporary but it will get you back on the road.
I don't know about the chain being able to handle more power. I haven't done any testing on that or seen any documentation. The polychain, which is what the name of the belt on our bikes is very, very strong & quite reliable. I manage a plant uses uses a ton of machinery. It's a very corrosive environment & we use stainless chain to drive a lot of our conveyors. The stainless stretches, kinks, wears out quite quickly & is very noisy. I'm in the process of switching everything over to polychain. I've only done a few pieces, but so far it's much quieter & the attention needed to keep it running is at a minimum.
So people just like the idea of a chain on their bike. My uncle owns a custom bike shop. He built his personal daily driver. The front is a '75 FXE/Shovelhead frame & the back is an '85 Softail frame. The flex in the Softail causes the chain wear out quickly, which is why HD went to a belt on the Softail. He made an auto chain tensioner out of a skateboard wheel & swears by the chain. He's ridden that bike all over the country in past 15 years & would never dream of switching to a belt. Different strokes for different folks.
Old Dec 30, 2010 | 08:08 PM
jluvs2ride's Avatar
jluvs2ride
From: Back in the Good Ole USA. South Carolina to be exact.
If you have time to ride, you're not properly maintaining your chain.
Old Dec 30, 2010 | 08:46 PM
PoCoBob's Avatar
PoCoBob
I got the chain handling more power thing from a buddy that works at a Suzuki / Kawasaki dealer. He told me that on their bikes 100 HP is about were they switch. Bikes with less come with belts, bikes with more come with chains.
Old Dec 30, 2010 | 09:49 PM
archergodwin's Avatar
archergodwin
Only reason I can think of is that the belt *might* jump a tooth sooner than a chain... but it's not for lack of tensile strength. I would also think it's a torque thing and not a HP thing.
Old Dec 30, 2010 | 09:52 PM
bigdaddy33's Avatar
bigdaddy33
Chain for all the reasons given above. It's been debated but high torque bikes can rip a belt.
Also, performance aside, a chain looks pretty cool.
Old Dec 30, 2010 | 11:35 PM
Fatbob usmc EOD's Avatar
Fatbob usmc EOD
I'll admit the chain looks pretty cool but the biggest I'm planning on going is a SE 103 with cams so I don't think I would need it. I'd rather save money on replacing chains by using a belt and get some more stuff powder coated so I can keep blacking out my bike.
Old Dec 31, 2010 | 12:01 AM
parts eeter's Avatar
parts eeter
The Yamaha Raider and Warrior are both high HP bikes and have belts.A mild big bore kit will not overstress the drive belt on a HD. It will shorten replacement intervals though. I will replace mine every 20k miles once I go big bore rather than 40k miles that I will currently replace at with a stock engine.
Old Dec 31, 2010 | 05:18 AM
ynots's Avatar
ynots
Originally Posted by KBFXDLI
Phooey to a chain....I want to convert to a shaft drive...
That would look awesome, you should also consider adding a radiator
Old Dec 31, 2010 | 06:04 AM
VTL nut's Avatar
VTL nut
I'd bet ya nailed it. Look at crotch rockets, all chain drive. A shaft would hold up, but think of the extra mass, as well as maintenance to keep it balanced, especially @ 100 mph plus.... They use banding in the making of the belts that can withstand gobs of torque and HP, (we use them on some servo's @ work) with the limiting factor being the contact surface of the ribs of the belts compared to chain and sprocket.
Personally, I love the belt from a maintenace standpoint. One less think to think about while out enjoying the weather.
