I have had both, the belt drive is just a lot less hassle, no grease on your pant legs, no grease or oil slung, no rusting, taking out links to make it tighter. I guess if you racing then some advantages.
So far nobody has mentioned it is a much easier,cheaper,lighter and more efficient way to change drive ratios.To most people who ride a cruiser this doesn't matter but there's a reason you dont see belts on too many sport bikes and zero dirt bikes.Once you convert to chain you can change final drive ratio sprockets for a fraction of the cost of a pulley.It would be interesting to see a breakdown of the cost difference between switching to a chain and changing to the equivilant of a 30T front pulley.I imagine the conversion would cost more but once you switched you could change sprockets for less.
I drag my 08 fatbob that runs 10.80-10.90's in the quarter mile just about every week an the belt holds up just fine....been almost two years now...attached is a pic from this past summer at the amra drags
Nice! Exactly what I needed to hear. In the middle of a 103/heads/cams build and I was wondering if I was going to have problems. It appears by your pic, I'm good-to-go!
There are members with 120R and billet motors using belt drives, standing up to truly serious performance increases.
Going back to the gearing issue, the range of gearing adjustments suitable for Harleys is not great, so the flexibility of using a chain is not essential, especially for road use. The TC96s are not as well off as the earlier bikes, due to the compensator design. I have a 21T compensator in my TC88, which is just great. Gives the bike much better get up and go. If the TC96s had a similar range of primary adjustment, that would suit most of us who want to change gearing. I haven't owned a bike with an open chain drive since the late 70s and ain't about to go backwards now!
