plug wire upgrade
Old May 23, 2006 | 11:44 PM
stc13's Avatar
stc13
Default plug wire upgrade
I changed my plug wires to taylor thundervolts 8.2 mm
these wires have a ferrite spiral wound coated core along with 50 ohms of resistance rfi and emi compatible
my question is will these do damage ?spoke to a H.D mech who said those wires deliver a harder spark and over time will
cause problems with my ignition ... whose got 2 cents
[IMG]local://upfiles/9083/C0D50A8B55F9492FAE7D263F48DA0EFD.jpg[/IMG]
Old May 23, 2006 | 11:49 PM
Shovelhead Bob's Avatar
Shovelhead Bob
Default RE: plug wire upgrade
Just wait.......
Your CEL will come on.....
Then it will stay on.......
Are those wires designed for a HD EFI System.......
Prolly not.....
You are messing with the ECM's ability to monitor and modify spark requirements, as well as sensing the complete and proper burn of the combustion chamber contents....
It's called ION Sense....
The coil sends out a constant 80 vdc and the ECM picks it up, and adjusts accordingly.....
Old May 23, 2006 | 11:53 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
you just got the $.02.........[sm=closed.gif]
Old May 24, 2006 | 12:00 AM
stc13's Avatar
stc13
I ve had them on for a month no light yet ...they said for 00-06 dyna models
however I saved old wires and will put back on I just read your info in the tec section about it
thanks bob
more paid training...[sm=icon_beat.gif]
Old May 24, 2006 | 01:08 PM
Spectrexx's Avatar
Spectrexx
Stick with the stock wires. Plug wires are plug wires. The stock ones work as well as the high-dollar ones. I use stock wires on my drag bikes, too.
Old May 24, 2006 | 02:48 PM
PowerCobra98's Avatar
PowerCobra98
How about the SE plug wires that are a larger diameter, are those ok?
I switched to those and have had no problems at all. I know that the ion sense is still working because when I data log with the SERT sometimes I'll get a rare knock and the system still retards timing.
Old May 24, 2006 | 05:37 PM
Spectrexx's Avatar
Spectrexx
ORIGINAL: PowerCobra98
More snake oil. They are no better than stock. You might also have trouble using a inductive timing light or ignition sensor for a dyno if the wires are too big around.
elmo4fun
EVO
May 13, 2018 11:49 AM
ironbobber2012
Apr 10, 2013 08:27 PM
1200efi
Jul 6, 2008 09:35 AM
paintballoma
Jun 8, 2007 04:41 AM
cowboy48
Apr 12, 2007 08:24 PM
