Tank swap confusion
Old Jul 23, 2009 | 09:00 PM
CountryPunk's Avatar
CountryPunk
Unhappy Tank swap confusion
Would someone mind clearing this up for me? I've searched and read until I'm blue in the face about tank swaps. I have a '99 FXDX. (Carbed of course) What are my options for bolt-on tank swaps, years and models? I have a nasty dent in the left side of my tank and would like to replace it eventually. I'm also curious about the possibility of switching to a tank mounted speedo, which years/models? If I've read right, I can even use tanks meant for FI if I remove the pump and swap to the pingel petcock/valve. Is this correct? I've read plenty about this subject, but a lot of info is contradictory and 99% of it is for much newer/FI/different model bikes. Thanks for your help.
Old Jul 23, 2009 | 10:42 PM
fixxr's Avatar
fixxr
try looking in the EVO listing
Old Jul 23, 2009 | 11:23 PM
CountryPunk
I didn't even think to look there, my bike being the first year for the TC. I'll check it out I guess.
Old Jul 23, 2009 | 11:52 PM
RKKY's Avatar
RKKY
1997-2003 FXD and FXDX are direct swaps. Just got a 99 FXDX Tank for the 00 FXD I am rebuilding. Don't have the part number here at home. Looked through the Dyna parts manuals to see which would work without any mods.
Old Jul 24, 2009 | 09:49 AM
CountryPunk
Ok, cool. That's a start. Thanks.
Old Jul 24, 2009 | 09:30 PM
icufltrn's Avatar
icufltrn
i have an 01 fxdxt and bought a 03 low rider tank. that way i will be able to mount the guages on the tank. i had looked at every after market supplier etc and couldn't find anything to fit or i liked. it is going to be expensive swap but i have been assured that everything is compatible. also looked at my service manual and the guages will mount right in.
Old Jul 25, 2009 | 04:11 AM
rounder's Avatar
rounder
99 to 03 lowrider tank and console setup. That will work for ya. the 04+ are designed a little differently and require mounting modifications to bolt to your frame.
Rusty19MCSFV
Jul 25, 2018 11:23 AM
mayhem912
Apr 7, 2018 10:40 AM
Garbonso
Jun 10, 2017 12:44 AM
RussH
Feb 3, 2015 06:53 AM
must8657
Aug 27, 2009 09:28 AM
