Inner Primary Leaking Still.......?
Old Jul 28, 2009 | 09:23 AM
eohdtech's Avatar
eohdtech
Default Inner Primary Leaking Still.......?
Ok, I cannot get my inner primary to quit leaking? Replaced all the seals on the primary and tranny, went for a 300 mile ride and the thing is still leaking. Anyone have a different fix for this? Or replace the seals and try it again?
Old Jul 28, 2009 | 09:40 AM
shimmon's Avatar
shimmon
When you replaced the seals did you check to make sure the mating surfaces were flat and smooth? If not, i'd pull it apart and make sure they are flat, not warped, cracked, scratched, etc.
Old Jul 28, 2009 | 12:01 PM
fixxr's Avatar
fixxr
Before you take it apart again,check with the bike on a lift with a light to see where the oil is coming from.Take it apart and make sure everything is cleaned and dried and use NEW gaskets .Do not over tighten bolts.DO NOT OVER FILL and check to see if vent is open.
Old Jul 28, 2009 | 12:04 PM
Phrogman's Avatar
Phrogman
Yeah, if you don't identify the exact spot the oil is coming from, you'll never get it fixed.
TK-Rider
2014-2024 Touring Models
Aug 2, 2014 08:11 AM
62pan
Aug 5, 2010 07:59 PM
eohdtech
Jul 29, 2009 09:51 AM
aagvain
Apr 15, 2008 05:19 PM
kman42oo
Aug 16, 2005 12:30 PM
