Apes on the way........what about cables
Old May 31, 2006 | 12:23 PM
TattooedAndScarred's Avatar
TattooedAndScarred
Default Apes on the way........what about cables
Ordered 13 inch apes........will i have to replace electrical wiring, or should i be ok? Second......how should i measure for correct cable lengths.....thanks
Old May 31, 2006 | 12:53 PM
phreak's Avatar
phreak
Default RE: Apes on the way........what about cables
electrical should be ok. I went to 14s and mine is phine. Didn't have to add anything. If your going internal, and your going to have to cut & solder anyway, you might consider adding some length to them.
When ordering replacement cables, you can refer to them as +3, or +6 which means 3" or 6" over the stock length.
phor the brake line, take a piece of kite string, and drape it along the path of your current brakeline, then measure that with a tape, then add the extra length, plus a little more.
NH-JK
Jun 8, 2012 10:04 PM
mobsters1972
Aug 18, 2010 03:00 PM
Skip
Feb 3, 2009 08:38 AM
Brackneyc
Dec 7, 2007 08:58 PM
LittleBrother
Nov 16, 2007 07:01 PM
