What front pegs?
Old Aug 13, 2009 | 08:03 PM
Titan56's Avatar
Titan56
Default What front pegs?
My 2003 Lowrider has forward control with stock pegs. If I go for a long ride, the vibration in the pegs put my feet to sleep. I was thinking of the Kuryakyn dually pegs, but i'm not sure if that will solve my problem.
Old Aug 13, 2009 | 08:11 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
A stock L/R will have mid controls with highway pegs up front. If you have the fwd controls with the stock rubbers, I would find something other than original. Also check your plugs make sure they are gapped the same. Usually .040 you'd be surprised what the plugs can do. If you are getting excessive vibs check your front tire pressure, 30 psi., tires over pressure, will transmit road imperfections.
Old Aug 13, 2009 | 08:25 PM
Titan56's Avatar
Titan56
The forward controls are a add on. The bike runs fine and the plugs are fine. It only has 1500mi. It is engine vibes through the frame. It is a normally vibration. I want to know what people are using pegs. I do alot of riding and want to be comfortable.
Old Aug 13, 2009 | 08:57 PM
Streets of Fire's Avatar
Streets of Fire
I have these on my 04 lowrider. Very comfortable. Not sure of the part number but its made by Kuryakyn.
Old Aug 13, 2009 | 09:07 PM
joe.1955's Avatar
joe.1955
Take a look at the Kuryakyn large ISO pegs with heel stirrups.
Gives you a chance to move your feet to a more comfortable position - or put the weight on your heels.
Old Aug 13, 2009 | 10:26 PM
danktat's Avatar
danktat
I have a set of these that I am not using because I replaced them with a set of mini floor boards. If you want them let me know.
Old Aug 14, 2009 | 08:43 AM
Prodriverdon's Avatar
Prodriverdon
Default I have the same
on my bike and they are VERY comfortable. Also change to a larger shift peg.
Old Aug 16, 2009 | 02:11 PM
Titan56's Avatar
Titan56
I bought a pair of Kuryakyn Switch Blades. What a world of a differences. There almost like having floor boards. There like a dually with a stirrups all in one. Thanks for the offer on the pegs, i'm not crazy about the looks of those.
06Sporty75
Sep 30, 2011 02:38 AM
tav311
Oct 26, 2009 09:50 AM
crawford769
Apr 29, 2009 05:43 PM
Aroberts
Apr 3, 2008 11:41 AM
ezahm44
Jan 24, 2008 10:40 PM
