Invert Gauge question
Old Aug 15, 2009 | 10:45 PM
Rgonot's Avatar
Rgonot
6th Gear
Default Invert Gauge question
So I am new to the Harley family and love my 2007 Dyna Superglide. The one thing I want to change is the handle bar speedo. I do not like how it sticks up and looks out of place. What I want to do is reverse it so it sits closer to the tank.
I have done some searches but cant find what I am looking for, anyone do this? Is there a part to buy that I can change out the pod? ANy help would be appreciated.
Old Aug 15, 2009 | 10:49 PM
bberck's Avatar
bberck
Cheapest way is to get a Sportster Custom set-up off ebay and use it.
I have the set-up off the 07 FXDSE its a nice option but on the expensive side to do.
Old Aug 15, 2009 | 10:58 PM
Rgonot's Avatar
Rgonot
6th Gear
thanks for the quick reply, that is exactly what I am looking for. Time to search ebay.
Old Aug 16, 2009 | 12:02 AM
SuperFastGlide's Avatar
SuperFastGlide
heres the sportster setup on my FXD the older straight sportster riser will clear a tank lift where as the newer curved back riser wont
Old Aug 16, 2009 | 02:57 AM
Rgonot's Avatar
Rgonot
6th Gear
I found one for 04-09 Sporster Custom riser speedo, is this the right one or do I need to look for an older one?
Old Aug 16, 2009 | 03:37 AM
Tnbrit's Avatar
Tnbrit
Default Riser
I fitted an 04'Sportster riser to my FXD,it fits no problem,if it's used make sure it's complete with back plate,plastic light cluster holder etc.the sperate parts are expensive,(don't ask how I know)if you want a pic let me know.
Old Aug 16, 2009 | 07:17 AM
bberck's Avatar
bberck
That one will work fine as long as you dont have a tank lift. If you want to have a tank lift then you will need the older style.
Old Aug 17, 2009 | 11:26 AM
stell55chevy's Avatar
stell55chevy
i dont wanna hijack the thread, but do you guys if u unhook the speedo and run without it, can u hook it up later and get a correct odometer reading?
Old Aug 17, 2009 | 11:55 AM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
Welcome to the forum! I hope there is some info on this subject for you in this thread:
https://www.hdforums.com/forum/dyna-...-question.html
Old Aug 17, 2009 | 01:12 PM
kk6pg's Avatar
kk6pg
No can do.
